Re: Ardun on the dyno
[Re: 605ply]
#2755248
03/23/20 10:14 PM
03/23/20 10:14 PM
Posts: 4,774 Star Idaho
67vertman
Star Idaho
Very nice and unique! What is it going in?
My Monster are real!
Living within your means makes life pretty easy.
[Re: mickm]
#2755257
03/23/20 10:48 PM
03/23/20 10:48 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
I'll be really surprised if it gets close to 400 HP,I was cutting my teeth on hot cars and hot rodding in the early 1960s, lots of Ardun powered street rods got their clocks clean regularly by dual quad 1957 Chevy 283 motors that had been hop up a little in 1957 Chevy bodies Those little carbs don't help either. Do you know which block was used and how many C.I. it has now? Those blocks only had three mains caps, spin them up to far and the pin would fall out of the grenade and go BOOM Sorry to be a party pooper. I really hope they break or make over 350HP Please keep all of us in the loop
[Re: Cab_Burge]
#2755304
03/24/20 06:11 AM
03/24/20 06:11 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I don’t mean to take anything away from a very cool build, but I would think 400 is extremely optimistic. Ive never had a chance to look at those heads in person, but I agree with Cab. If the airflow is there, with the small bore/ displacement, you still need RPM to make HP. And as said, three main caps on these blocks. Thats a lot of unsupported crank span! Very neat engine. Hope his goals are achieved.
[Re: TRENDZ]
#2755306
03/24/20 06:49 AM
03/24/20 06:49 AM
Posts: 621 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Not an Ardun (yet) but the 290 ci blown FH I built ok There's quite a few 325-250HP mild boost, blown FHs getting around that are not Ardun headed. I built mine with a 4 1/8" crank, H beams, Ross forged slugs and all three studded caps are billet steel. A short fill to the block, I ported it, added 1.6 in/ex valves, a custom blower cam and adjustables. Dual Stromberg WW 2 BBLs, it runs 8lbs of boost on pump 98 down here. Other than a popped head gasket, its been dead nuts reliable and after a recent teardown / inspection the bearings looked brand new
[Re: quickd100]
#2755329
03/24/20 08:20 AM
03/24/20 08:20 AM
Posts: 4,687 Wichita
GY3
Wichita
The ARDUN heads were originally designed for garbage trucks because the OE flatheads didn't have enough power.
I've never understood the infatuation with the pre-war relic platform. Seems like a lot of trouble for little horsepower.
Then again, people still race horses...
[Re: GY3]
#2755331
03/24/20 08:31 AM
03/24/20 08:31 AM
Posts: 232 NYC
Dartari
NYC
I still The ARDUN heads were originally designed for garbage trucks because the OE flatheads didn't have enough power.
Then again, people still race horses... Its called cool factor to be different Is still what gives juice to our hobby
[Re: Dartari]
#2755354
03/24/20 09:35 AM
03/24/20 09:35 AM
GY3
Wichita
Then again, people still race horses... Its called cool factor to be different Is still what gives juice to our hobby I get that and still appreciate the visual art of them. Same with ricers. I can appreciate good work no matter what the platform. Just not for me. I guess it's what you grew up around.
[Re: polyspheric]
#2755370
03/24/20 10:21 AM
03/24/20 10:21 AM
TRENDZ
Milwaukee WI
Looks like it sort of. Heres a gennie...
[Re: moparx]
#2755431
03/24/20 12:31 PM
03/24/20 12:31 PM
TRENDZ
Milwaukee WI
My only experience with a flat head ford was with my neighbor. He’s building an “A” hotrod. Wanted me to relive the block. I had no idea what he was talking about, until he showed me😀. Turned out nice.
[Re: mickm]
#2755440
03/24/20 01:03 PM
03/24/20 01:03 PM
Posts: 4,209 New York
polyspheric
New York
IDT 400 hp is going to happen. That exhaust tells me that the cam is mild.
Boffin Emeritus
