Rich at idle! Help! #2754716
03/22/20 07:24 PM
03/22/20 07:24 PM
junction city oregon
V
viperblue72 Offline OP
V
I have a 440 in my ramcharger with a 4150/1050 proform. No matter what I do it runs rich at idle.
I set the throttle blades to show the transfer slots just as I should, set the idle mixture screws 1.5 turns.
Checked the power valve, opened up the idle bleeds from 73 to 76.
It has around 8” vacuum currently. It has 10” if I turn the idle up a little.
But no matter what I do it has little to no effect on a/f ratio of 10.8-11.2.
I’m at a loss.
It cruises around 12.5 and is around 12.5 at full throttle.
Re: Rich at idle! Help! [Re: viperblue72] #2754732
03/22/20 07:52 PM
03/22/20 07:52 PM
AndyF Offline
AndyF  Offline
If the idle screws don't make much difference then you need to reduce the size of the idle restriction in the metering block. Depending on which carb you have the IFR might be a drilled hole or it might be a jet.
Re: Rich at idle! Help! [Re: AndyF] #2754744
03/22/20 08:23 PM
03/22/20 08:23 PM
in the middle
dodger mope Online content
dodger mope  Online Content
in the middle
after shut down for 5 or 10 minutes,does it restart with long crank or blubber- it could be a internal leak like a power valve
Re: Rich at idle! Help! [Re: viperblue72] #2754746
03/22/20 08:26 PM
03/22/20 08:26 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
No matter what you do??
Can you stall the motor by turning the mixture screws all the way in?
If so, I’d say the circuits are functioning properly...... and probably need a different calibration.
If it won’t shut off by turning the screws all the way in....... then figure out where it’s getting fuel from when the screws are all the way in.
Re: Rich at idle! Help! [Re: fast68plymouth] #2754756
03/22/20 08:43 PM
03/22/20 08:43 PM
V
V
It does die if I turn the mixture screws too far. But to the point it doesn’t like it, doesn’t change the a/f much at all.
When I took the idle bleeds out of the primary completely it went to 12.2 but then the accelerator pump didn’t work the way it should. I put a 4.5 pv just now and it made no difference.
Re: Rich at idle! Help! [Re: dodger mope] #2754757
03/22/20 08:45 PM
03/22/20 08:45 PM
V
V
It starts and drives no problem at all even after sitting. And it does run just fine. I just can’t get the idle to stop running rich.
Re: Rich at idle! Help! [Re: AndyF] #2754758
03/22/20 08:47 PM
03/22/20 08:47 PM
V
V
It does have jets inside on the metering block on both sides of the power valve, along with holes that appear to be for jets. I bought the carburetor new so those are whatever came on the carb. And I don’t know what those do.
Re: Rich at idle! Help! [Re: viperblue72] #2754759
03/22/20 08:50 PM
03/22/20 08:50 PM
V
V
For what it is worth it didn’t seem the idle mixture screws made any difference for vacuum either. When I opened them past 1.5 the vacuum didn’t go up.
Re: Rich at idle! Help! [Re: viperblue72] #2754764
03/22/20 09:07 PM
03/22/20 09:07 PM
V
V
Ok now that I have made other adjustments I’m not sure what caused this but now the screws are leaning the mixture. What is the most you want to turn these in? I’m at 12.2 now and the screws are about one full turn out. But now it stumbles really bad when I try to take off.
Re: Rich at idle! Help! [Re: viperblue72] #2754768
03/22/20 09:24 PM
03/22/20 09:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Lean it down a 1/4 turn and open the blade to get the rpm back
wave
Re: Rich at idle! Help! [Re: viperblue72] #2754776
03/22/20 09:45 PM
03/22/20 09:45 PM
The carb should idle on the idle circuits, if it is 4 corner idle adjust both throttle shafts, so the throttle plate DO NOT expose the transfer slots tskscope wrench If they are exposed at all it is not idling on the idle circuits only like it should twocents
Years ago some one on here started the misinformation about exposing the transfer slots to make THEIR carb idle instead of fixing their real issues with that carb rant down
Re: Rich at idle! Help! [Re: MR_P_BODY] #2754786
03/22/20 10:03 PM
03/22/20 10:03 PM
V
V
I’ll give that a try next but now it’ll have to wait until tomorrow.
Re: Rich at idle! Help! [Re: viperblue72] #2754804
03/22/20 10:52 PM
03/22/20 10:52 PM
AndyF Offline
AndyF  Offline
Those are probably the emulsion jets. The idle feed restrictions will be in the upper corners. Maybe post a picture of your metering block and someone will show you what is what.
Re: Rich at idle! Help! [Re: MR_P_BODY] #2754831
03/23/20 12:28 AM
03/23/20 12:28 AM
CA
crackedback Offline
crackedback  Offline
CA
Smaller IFR or larger IAB would be a start.
Try dropping the float level slightly. That will help sometimes to clean up idle.
You should have more control over the idle setting, my guess is a smaller IFR so the mixture screw is less sensitive to movement, requires more movement to alter A/F ratio.
Make sure you have initial timing in the correct spot too.
Re: Rich at idle! Help! [Re: crackedback] #2754833
03/23/20 12:32 AM
03/23/20 12:32 AM
AndyF Offline
AndyF  Offline
Yes, timing with a big cam should be at least 20 or 25 degrees. Smaller IFRs usually solve the idle tuning problem but sometimes it just takes a little more timing.
Re: Rich at idle! Help! [Re: AndyF] #2755014
03/23/20 01:14 PM
03/23/20 01:14 PM
V
V
Cam is only 230@050 and 112lsa. 050. 9.8 compression rpm intake. Motor made 490hp/553tq.
I did open up the idle air bleeds to 76 from 73. It’s more responsive to adjusting the idle screws.
I got it to 12.2 by closing them up to 3/4 or 1 turn out I can’t remeber exactly. But now it stumbles and dies when I try to take off.
Next idle try to open up the butterflies some to see if it helps, but doesn’t that uncover too much of the slot?
Timing is 18initial 36 total.
Re: Rich at idle! Help! [Re: viperblue72] #2755026
03/23/20 01:33 PM
03/23/20 01:33 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Maybe re calibrate your Gauge
Re: Rich at idle! Help! [Re: CSK] #2755044
03/23/20 02:21 PM
03/23/20 02:21 PM
V
V
I believe the gauge is pretty accurate, being what I saw on the dyno through the rpm range
Was consistent with that I seen on this gauge when I put it in the truck.
FWIW the idle wasn’t this rich when I first installed the engine. Which leads me to believe it is something I am doing wrong.
I installed this on my cuda and had to make adjustments then put it back on the truck.
It doesn’t seem to run rich at idle on that motor which is a 410” with big Indy single plane and much bigger cam.
Re: Rich at idle! Help! [Re: viperblue72] #2755046
03/23/20 02:29 PM
03/23/20 02:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It sounds like one(or more) of the bleed are plugged with trash or something
wave
Re: Rich at idle! Help! [Re: viperblue72] #2755047
03/23/20 02:32 PM
03/23/20 02:32 PM
Check your exhaust system for air leaks, they will really mislead the O2 sensor and gauge scope
