Page 3 of 5 1 2 3 4 5
Re: Engine sits for about a weekend and have no oil pressure. [Re: lockjaw-express] #2753230
03/18/20 06:40 PM
03/18/20 06:40 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Originally Posted by lockjaw-express
Originally Posted by Sammy
Now I'm really baffled.
Got a loop in the line at the back oil line.
Front line goes up and over pump, so that one definitely holds oil in the filter. Tightened up all the fittings again. I was able to tighten them up more for some reason.
I started it up and now only 3 days and it lost prime.
Turned off ignition and turned it on and it took about 20 seconds to get oil pressure.
I did use the oil accumulator and got 25 psi shot into the motor.
But oil pressure did not go up quick enough for my liking.
Wondering if they make a 1 way check valve for the bottom oil line?
Going to try again tomorrow and if I lose prime again I'm going to change out the oil filter back to my trusty WIX.
Sammy, mine does the same with the Wix and Mobil1 filters, and mine does what yours does, exactly. I am now thinking the filter is full, but the oil in the pump drains back into the engine and loses its prime. In the summer heat, I sometimes get pressure right away.
I am thinking if there is a way to prime the engine with the accumulator off of the front of the oil pump...maybe that would work???
Mark
Mark. my oil accumulator sandwich is between the pump and oil filter. When I hit the switch, I'm sure that oil must go into the line I'm going to see if I can raise the rear oil line above the oil pump tomorrow, somehow. I might have to change a fitting or 2 to get the line up. I hate seeing no oil pressure for 20-25 seconds. Never had this problem before.
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2753240
03/18/20 07:12 PM
03/18/20 07:12 PM
gregsdart Online content
gregsdart  Online Content
Anyone running thier motor without oil pressure for 15 to 25 seconds better look at your bearings. Mine were starting to smear bearing material. Your results may vary.
Re: Engine sits for about a weekend and have no oil pressure. [Re: gregsdart] #2753382
03/19/20 08:52 AM
03/19/20 08:52 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
This has been on my mind.
Just wondering if the accumulator might help with this problem?
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2753570
03/19/20 05:40 PM
03/19/20 05:40 PM
My bracket car, with two different motors with different dual line Milidon oiling systems hasn't had any pressure problems when sitting for months at a time in the car trailer during the winters here, it has got down to-25F two years ago. I have ran 5w20Wt oil and 10x30 VR1 oil in the car since day one of me racing it 6 yrs. ago up work
I think I had more issues with straight 50Wt and later with 20W50Wt oil loosing the prime, even with Kendall GT1 20x50Wt oil shruggy work
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2753975
03/20/20 10:11 PM
03/20/20 10:11 PM
Ohio
lockjaw-express Offline
Ohio
Sammy,
I looked at the Indy Billet oil pump today...the pump looks to be cast Iron (Indy part) and the cover is two piece. There is a cover bolted on the pump, then an adapter for the oil filter. On the top of the Oil filter adapter there is a single 1/4" pipe plug on the top. I will call Indy on Monday to find out if my accumulator could or should be plumbed into there???
Mark
Re: Engine sits for about a weekend and have no oil pressure. [Re: lockjaw-express] #2754064
03/21/20 08:17 AM
03/21/20 08:17 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Sammy,
Mark
Yes that's where I had mine on.
I wish I never switched from Indys pump setup.
Never an issue.
-10an line to the 1/4 port.
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2754082
03/21/20 09:10 AM
03/21/20 09:10 AM
Ohio
Ohio
Sammy,
Mark
Never an issue.
Sammy,
Attaching the accumulator to that port, would it prevent the pump from losing the prime? and still pre-oil the bearings?
Mark
Re: Engine sits for about a weekend and have no oil pressure. [Re: lockjaw-express] #2754097
03/21/20 09:49 AM
03/21/20 09:49 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Sammy,
Mark
Never an issue.
Sammy,
Mark
Mark. I have my accumulator on a solenoid switch.
When I'm ready to turn off the motor, I rev up the engine to get maximum oil pressure, then turn off the switch.
It will hold my75psi till I turn the switch back on to prime the engine.
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2754120
03/21/20 11:28 AM
03/21/20 11:28 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
You guys have mentioned the shape and angle of the feed line. Does mine look ok? I haven't really had any problems but it takes about 3 or 4 seconds to show oil pressure when I fire it up, but I don't know if that's just because of how long it takes the electric oil pressure gauge to react?
I have a habit of letting the motor turn over for about 5 seconds before hitting the ignition toggle switch just to get the oil moving but I don't know if that's good for a motor or not?
I've done this for many years with no problems but I'm always willing to learn.
Re: Engine sits for about a weekend and have no oil pressure. [Re: ProSport] #2754166
03/21/20 12:44 PM
03/21/20 12:44 PM
The delay is probably the sender, that assuming your using a BB and your taking the pressure reading off of the back of the block, which has to fill all the oil passages up before making pressure work shruggy
I wouldn't and don't spin the motor over on the starter any longer than it takes for the motor to fire, why do that work
I know, it is a old Chevy racer trick tsk
Re: Engine sits for about a weekend and have no oil pressure. [Re: Cab_Burge] #2754168
03/21/20 12:49 PM
03/21/20 12:49 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Ok thanks Cab, that's about what I figured.
As far as spinning the motor for a few seconds before hitting the ignition, that's only for the first start of the day(or week), my theory has always been that it would get the oil moving for a few seconds before the motor is fired and spinning really fast, but if you guys think it's completely un-necessary I probably won't do it anymore.
Does the oil feed line look ok in my photo?
Re: Engine sits for about a weekend and have no oil pressure. [Re: ProSport] #2754192
03/21/20 02:17 PM
03/21/20 02:17 PM
That line looks good to me up
As far as trying to get a BB Mopar oil system to make pressure don't you think it will make pressure quicker at 800+ RPM running than at less than 100 RPM on the starter work whistling grin
Chevy oil pump with pickup and pump submerged in oil versus a BB Mopar having to suck oil up into the external mounted pump, two different animals twocents work
Re: Engine sits for about a weekend and have no oil pressure. [Re: ProSport] #2754223
03/21/20 03:26 PM
03/21/20 03:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont.. you need a hump in that line to act as a trap.. right now your draining about 90% back of what you have
wave
Re: Engine sits for about a weekend and have no oil pressure. [Re: MR_P_BODY] #2754226
03/21/20 03:34 PM
03/21/20 03:34 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
wave
That's what my thought is as well.
How fast do you think it takes for all the oil to drain out and lose prime.
Mines very similar but mine has a little more of a hump.
So far 2 days and I still have prime. Don't think 2 more days will have prime.
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2754236
03/21/20 03:59 PM
03/21/20 03:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would depend on the clearances.. mainly the pump and the oil level... I use to run a fairly tight radius on the
hump to keep the air volume down to a minimum and try to keep the hump close to the pump(again less air
volume)
wave
Re: Engine sits for about a weekend and have no oil pressure. [Re: MR_P_BODY] #2754244
03/21/20 04:14 PM
03/21/20 04:14 PM
Ohio
Ohio
volume)
wave
Hi Mike,
I do not have hump in the feedline to the pump, as one of the header tubes is very close to the AN -12 hose. I use a 45* fitting at the pump, and right angle at the pickup..
That is why I was asking if I would be better off to run the Accumulator to the fitting on top of the Indy filter adapter, instead of running an AN -6 hose to the back/top of the block.
Thanks for any advice, Mark
Re: Engine sits for about a weekend and have no oil pressure. [Re: lockjaw-express] #2754257
03/21/20 04:32 PM
03/21/20 04:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
volume)
wave
Hi Mike,
I never ran a accumulator so I cant say to that,, all I know is you want a large volume of oil to dump quickly
so you want a good size port... I bought a accumulator but never hooked it up
wave
Re: Engine sits for about a weekend and have no oil pressure. [Re: lockjaw-express] #2754258
03/21/20 04:32 PM
03/21/20 04:32 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
volume)
wave
Hi Mike,
Minimum of -8an is recommended and I believe the back of the block is NOT advisable to use as a prelube.
Re: Engine sits for about a weekend and have no oil pressure. [Re: Sammy] #2754261
03/21/20 04:38 PM
03/21/20 04:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
volume)
wave
Hi Mike,
Are you talking the oil pressure line supply port.. if you are thats a 1/8" and by the time you put a fitting in it
that would be WAY to small
wave
Re: Engine sits for about a weekend and have no oil pressure. [Re: MR_P_BODY] #2754424
03/22/20 08:49 AM
03/22/20 08:49 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
wave
Mike, I'll make a new line with a 45 degree fitting at the oil pump, that should give a small hump up there to keep oil in the pump. Sound correct?
