SB WINDAGE TRAYS #2754009
03/21/20 01:00 AM
03/21/20 01:00 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Haven't found any evidence other than commentary on the subject. Factory windage trays loose power? Aftermarket windage trays loose power(not including crank scraper)? Any hard evidence, something like a real design, where the tray does its job and makes power? No" dry sump" as the solutions please.
Re: SB WINDAGE TRAYS [Re: A/MP] #2754031
03/21/20 02:28 AM
03/21/20 02:28 AM
I use to race NHRA stock in Division 7, there was a lot of record holding SB Mopar racers racing back then, none of them ran a windage tray, stock or after market work
All of them had crank scrapers and added weld in baffles in the stock oil pans up
I use to help one of them, he ended setting the record in several different classes during his racing career with 340 motors, he did do a lot of testing both at the track and on a engine dyno wrench
He tested several different windage trays and didn't race with one ever that I know of work
Crankshaft scrapers with between .030 and .060 clearances are worth running up wrench grin
Re: SB WINDAGE TRAYS [Re: A/MP] #2754040
03/21/20 06:23 AM
03/21/20 06:23 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Don't know if this is the same on a S/B but on my RB if we didn't run a windage tray we would lose some oil pressure (20 psi) in the shut down.
Re: SB WINDAGE TRAYS [Re: Cab_Burge] #2754061
03/21/20 08:10 AM
03/21/20 08:10 AM
E
earlymopar Offline
earlymopar  Offline
E
Who manufactures and sells small block crank scrapers?
- EM
Re: SB WINDAGE TRAYS [Re: earlymopar] #2754088
03/21/20 09:34 AM
03/21/20 09:34 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
- EM
https://crank-scrapers.com/
Re: SB WINDAGE TRAYS [Re: Cab_Burge] #2754106
03/21/20 10:28 AM
03/21/20 10:28 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
How much oil did he run? My guess is a lot less than most folks here would be comfortable with. Thanks!
Re: SB WINDAGE TRAYS [Re: 340Cuda] #2754113
03/21/20 10:45 AM
03/21/20 10:45 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I gave up using them years ago.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SB WINDAGE TRAYS [Re: 340Cuda] #2754162
03/21/20 12:34 PM
03/21/20 12:34 PM
All the guys I knew back then ran 4 quarts in a 4 quart stock oil pan shruggy
the one I helped eventually went to a oil pan off of a Cordoba that was a little deeper, he added a half of a quart also at that time. Adding the anti slosh baffles, front and rear, really helped on keeping the oil pressure steady at both ends of the track up
Re: SB WINDAGE TRAYS [Re: Cab_Burge] #2754194
03/21/20 02:21 PM
03/21/20 02:21 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I have run windage trays on my small blocks and found no big differences. But for the low RPM cop cars the tests were positive. My LRT had one. On the 5.2L or 5.9L Dakota oil pans, 4 qt, there is no room as the pans are shallower, closer to the crank. I don't think you could, or should, run a stock Dak/Durango pan on a 4" or 4.125" stroker crank.
I bought the $110 Crank Scraper kit from Ishihara Johnson (crank-scrapers.com) for my 4 inch stroker 5.9 410. It is a bear to fit. You must fit it to the crank and block. The oil pan bolt holes are undersize. The stand offs for the main caps do not line up. The dip stick hole is way off. Then you must seal it to the block and pan as it is thick and will leave a gap at the front timing cover and rear main cap.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: SB WINDAGE TRAYS [Re: Dave_J] #2754196
03/21/20 02:27 PM
03/21/20 02:27 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
The easiest scraper is one welded inside the pan. No extra gasket + RTV thickness needed.
Done as a downward angle on the cranks upward swing it will grab the loose mass of oil clinging to the crank. Here are two pictures of a Hamburger and Canton Chevy pans as an example.
You could do the 0.030' to 0.060' fitting to this side scraper too.
65 Formula S Cuda
Re: SB WINDAGE TRAYS [Re: Dave_J] #2754197
03/21/20 02:28 PM
03/21/20 02:28 PM
Washington
madscientist Offline
Washington
I bought the IJ scraper but I bought the Teflon scraper. I didn't have near that much fitting on mine.
I also think that a running clearance of near zero is better than the .030-.060 you need with just a steel scraper.
Re: SB WINDAGE TRAYS [Re: Dave_J] #2754198
03/21/20 02:29 PM
03/21/20 02:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I wouldn't spend money on a scraper.
I would make a pattern on an assembled engine and fab one up. With all the different parts combinations, how could they begin to make one and hope to have it be close.
Re: SB WINDAGE TRAYS [Re: CMcAllister] #2754210
03/21/20 03:02 PM
03/21/20 03:02 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
This is kind of my point above. Lots of work making it right and even then it is still not right. I'd need to weld it up in places and add some steel to other places.
I will put clay in the bottom of my Milodon truck rear sump pan and then carve out a side scraper that fits 0.030" - 0.060" to my 4" throws and weld it to the pans side. I will also be adding baffels to that pan.
And I am running a 5/8" pipe direct pump pickup like below. That stock 5.2 3/8" pump pickup gets a 3/8 pipe plug in the oil pump hole..
I will run 6 quarts in that 8 qt pan but cut the dipstick tube to fit.
65 Formula S Cuda
Re: SB WINDAGE TRAYS [Re: Dave_J] #2754234
03/21/20 03:51 PM
03/21/20 03:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why are you running 2 pick up points
wave
Re: SB WINDAGE TRAYS [Re: MR_P_BODY] #2754235
03/21/20 03:56 PM
03/21/20 03:56 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
wave
wink Just a side by side compare.
The factory one will be removed and a pipe plug screwed in the pump. The new pump cover type pickup has a 0.625 inch ID tube.
65 Formula S Cuda
Re: SB WINDAGE TRAYS [Re: Dave_J] #2754241
03/21/20 04:09 PM
03/21/20 04:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run just a scraper now days.. use to run a windage tray but I had to open up all the slots so it would work..
now I just run a bigger pan with the scraper.. no problems at 8200+ rpm and keep the oil level lower
wave
Re: SB WINDAGE TRAYS [Re: A/MP] #2754267
03/21/20 05:05 PM
03/21/20 05:05 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
So, to the OP, it seems that those that have been doing this for years do not think it has value. I too agree that in my low level bracket/grudge racing I have not seen any improvements just by adding a tray. Never did any Dyno testing on small blocks back in my racing/hot rod days.
In the tests by the Mopar test group back in the days I seem to remember they were getting some HP gains but everyone was only reving their engines to 6,000 or so back then.
E-58 small block cop car engine would only rev to 5,500 in most cases, first gear was locked out with a bracket.
So, as posted above, a better course would be a deeper sump with the same amount of oil down lower in the sump, proper baffels and a scraper of some sort.
65 Formula S Cuda
Re: SB WINDAGE TRAYS [Re: MR_P_BODY] #2754281
03/21/20 06:09 PM
03/21/20 06:09 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
wave
Same reason for someone to run a dual line on a big block. I've fabed systems and ran them. Not hard to do. Worked well
Re: SB WINDAGE TRAYS [Re: CMcAllister] #2754283
03/21/20 06:16 PM
03/21/20 06:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself I wouldnt waste my time with dual inlets.. a 1/2" inlet is more than you need so why carry the extra
weight and pluming.. just more possible leaks
wave
Re: SB WINDAGE TRAYS [Re: MR_P_BODY] #2754295
03/21/20 07:10 PM
03/21/20 07:10 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
wave
Edited my last post above. 1 single pickup, the bolt on pump cover one.
Tests I read said that this pump "Cover Type" pickup with a standard volume pump will flow more oil than a stock pickup with a Melling high volume pump.
The stock pickup is a huge bottle neck. I have seen some that are thick tube outside but small inside diameter. The biggest inside diameter ones I have seen are 1/2 inch inside until 1 inch from the pump and then necked down to that 3/8s pipe screw in.
65 Formula S Cuda
