How Much is Too Much Voltage #2754056
03/21/20 08:02 AM
03/21/20 08:02 AM
PA
70Duster Offline OP
70Duster  Offline OP
PA
I recently had to replace the voltage regulator on my 1987 Dodge Dakota 3.9L V-6. The original problem was that the voltage regulator was not allowing the alternator to sufficiently charge the battery. Measuring the voltage across the battery while running I was only getting about 12.3 volts and the gauge on the dash was showing lower charge than normal. The alternator was tested and showed that it was good.
So I replaced the voltage regulator with a brand new one and the gauge is now reading higher than normal even after several hundred miles of driving long after the battery has been fully charged up. Measuring across the battery with the new regulator, I' m getting 14.7 volts. I was expecting around 14.3 or 14.5. Is 14.7 volts too high? I don't want to cook the 1 year old battery.
Re: How Much is Too Much Voltage [Re: 70Duster] #2754066
03/21/20 08:25 AM
03/21/20 08:25 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: How Much is Too Much Voltage [Re: 70Duster] #2754068
03/21/20 08:27 AM
03/21/20 08:27 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Under 15v is fine.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: How Much is Too Much Voltage [Re: GoodysGotaCuda] #2754075
03/21/20 08:49 AM
03/21/20 08:49 AM
PA
70Duster Offline OP
70Duster  Offline OP
PA
Sounds good. Thanks!
Re: How Much is Too Much Voltage [Re: GoodysGotaCuda] #2754221
03/21/20 03:25 PM
03/21/20 03:25 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Originally Posted by GoodysGotaCuda
Under 15v is fine.
Yep. Anything above 15 volts will cause battery and equipment damage and if it shows 16+ volts you have a shorted cell and may get a big BOOM when the fluid boils down.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: How Much is Too Much Voltage [Re: Dave_J] #2754286
03/21/20 06:24 PM
03/21/20 06:24 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Remember to check for a valid ground to your externally regulated Dodge's voltage regulator case.It's the reguators job to control the grounding of the field circuit of the alternator to provide the correct charging voltage to the battery circuit. It's mounting bolts and surface are its connection to the body for grounding .must be clean metal to metal connection.Also verify good groundwire and clean connection from negative battery terminal to body. Use a jumper wire from v. regulator body to neg. battery terminal and look for a spark or change in charging voltge, which indicates poor body ground circuit to regulator and need to be fixed. Pretty commonly overlooked in older vehicles. Bill
