Re: SB WINDAGE TRAYS
[Re: A/MP]
#2754031
03/21/20 02:28 AM
03/21/20 02:28 AM
Posts: 43,312 Bend,OR USA
Cab_Burge
I use to race NHRA stock in Division 7, there was a lot of record holding SB Mopar racers racing back then, none of them ran a windage tray, stock or after market ![work work](/ubbthreads/images/graemlins/custom/work.gif) All of them had crank scrapers and added weld in baffles in the stock oil pans ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I use to help one of them, he ended setting the record in several different classes during his racing career with 340 motors, he did do a lot of testing both at the track and on a engine dyno ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) He tested several different windage trays and didn't race with one ever that I know of ![work work](/ubbthreads/images/graemlins/custom/work.gif) Crankshaft scrapers with between .030 and .060 clearances are worth running ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: A/MP]
#2754040
03/21/20 06:23 AM
03/21/20 06:23 AM
Posts: 2,937 A shed in England
Tig
A shed in England
Don't know if this is the same on a S/B but on my RB if we didn't run a windage tray we would lose some oil pressure (20 psi) in the shut down.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Cab_Burge]
#2754106
03/21/20 10:28 AM
03/21/20 10:28 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I use to race NHRA stock in Division 7, there was a lot of record holding SB Mopar racers racing back then, none of them ran a windage tray, stock or after market ![work work](/ubbthreads/images/graemlins/custom/work.gif) All of them had crank scrapers and added weld in baffles in the stock oil pans How much oil did he run? My guess is a lot less than most folks here would be comfortable with. Thanks!
[Re: 340Cuda]
#2754113
03/21/20 10:45 AM
03/21/20 10:45 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I gave up using them years ago.
[Re: Cab_Burge]
#2754194
03/21/20 02:21 PM
03/21/20 02:21 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I have run windage trays on my small blocks and found no big differences. But for the low RPM cop cars the tests were positive. My LRT had one. On the 5.2L or 5.9L Dakota oil pans, 4 qt, there is no room as the pans are shallower, closer to the crank. I don't think you could, or should, run a stock Dak/Durango pan on a 4" or 4.125" stroker crank.
I bought the $110 Crank Scraper kit from Ishihara Johnson (crank-scrapers.com) for my 4 inch stroker 5.9 410. It is a bear to fit. You must fit it to the crank and block. The oil pan bolt holes are undersize. The stand offs for the main caps do not line up. The dip stick hole is way off. Then you must seal it to the block and pan as it is thick and will leave a gap at the front timing cover and rear main cap.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2754196
03/21/20 02:27 PM
03/21/20 02:27 PM
Dave_J
Auburn WA
The easiest scraper is one welded inside the pan. No extra gasket + RTV thickness needed.
Done as a downward angle on the cranks upward swing it will grab the loose mass of oil clinging to the crank. Here are two pictures of a Hamburger and Canton Chevy pans as an example.
You could do the 0.030' to 0.060' fitting to this side scraper too.
[Re: Dave_J]
#2754197
03/21/20 02:28 PM
03/21/20 02:28 PM
Posts: 4,457 Washington
madscientist
Washington
I bought the IJ scraper but I bought the Teflon scraper. I didn't have near that much fitting on mine.
I also think that a running clearance of near zero is better than the .030-.060 you need with just a steel scraper.
[Re: Dave_J]
#2754198
03/21/20 02:29 PM
03/21/20 02:29 PM
Posts: 11,737 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I wouldn't spend money on a scraper.
I would make a pattern on an assembled engine and fab one up. With all the different parts combinations, how could they begin to make one and hope to have it be close.
[Re: CMcAllister]
#2754210
03/21/20 03:02 PM
03/21/20 03:02 PM
Dave_J
Auburn WA
I also think that a running clearance of near zero is better than the .030-.060 you need with just a steel scraper. I wouldn't spend money on a scraper.
I would make a pattern on an assembled engine and fab one up. With all the different parts combinations, how could they begin to make one and hope to have it be close. This is kind of my point above. Lots of work making it right and even then it is still not right. I'd need to weld it up in places and add some steel to other places. I will put clay in the bottom of my Milodon truck rear sump pan and then carve out a side scraper that fits 0.030" - 0.060" to my 4" throws and weld it to the pans side. I will also be adding baffels to that pan. And I am running a 5/8" pipe direct pump pickup like below. That stock 5.2 3/8" pump pickup gets a 3/8 pipe plug in the oil pump hole.. I will run 6 quarts in that 8 qt pan but cut the dipstick tube to fit.
![Name: 4a.jpg
ID: 388130 4a.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/388130/filename/4a.jpg)
[Re: Dave_J]
#2754234
03/21/20 03:51 PM
03/21/20 03:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would make a pattern on an assembled engine and fab one up. With all the different parts combinations, how could they begin to make one and hope to have it be close. This is kind of my point above. Lots of work making it right and even then it is still not right. I'd need to weld it up in places and add some steel to other places. I will put clay in the bottom of my Milodon truck rear sump pan and then carve out a side scraper that fits 0.030" - 0.060" to my 4" throws and weld it to the pans side. I will also be adding baffels to that pan. And I am running a 5/8" pipe direct pump pickup like below. That stock 5.2 3/8" pump pickup gets a 3/8 pipe plug in the oil pump hole.. I will run 6 quarts in that 8 qt pan but cut the dipstick tube to fit. Why are you running 2 pick up points ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2754235
03/21/20 03:56 PM
03/21/20 03:56 PM
Dave_J
Auburn WA
I will run 6 quarts in that 8 qt pan but cut the dipstick tube to fit. Why are you running 2 pick up points ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) Just a side by side compare. The factory one will be removed and a pipe plug screwed in the pump. The new pump cover type pickup has a 0.625 inch ID tube.
[Re: Dave_J]
#2754241
03/21/20 04:09 PM
03/21/20 04:09 PM
MR_P_BODY
I run just a scraper now days.. use to run a windage tray but I had to open up all the slots so it would work.. now I just run a bigger pan with the scraper.. no problems at 8200+ rpm and keep the oil level lower ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: A/MP]
#2754267
03/21/20 05:05 PM
03/21/20 05:05 PM
Dave_J
Auburn WA
Haven't found any evidence other than commentary on the subject. Factory windage trays loose power? Aftermarket windage trays loose power(not including crank scraper)? Any hard evidence, something like a real design, where the tray does its job and makes power? No" dry sump" as the solutions please. So, to the OP, it seems that those that have been doing this for years do not think it has value. I too agree that in my low level bracket/grudge racing I have not seen any improvements just by adding a tray. Never did any Dyno testing on small blocks back in my racing/hot rod days. In the tests by the Mopar test group back in the days I seem to remember they were getting some HP gains but everyone was only reving their engines to 6,000 or so back then. E-58 small block cop car engine would only rev to 5,500 in most cases, first gear was locked out with a bracket. So, as posted above, a better course would be a deeper sump with the same amount of oil down lower in the sump, proper baffels and a scraper of some sort.
[Re: MR_P_BODY]
#2754281
03/21/20 06:09 PM
03/21/20 06:09 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Why are you running 2 pick up points Same reason for someone to run a dual line on a big block. I've fabed systems and ran them. Not hard to do. Worked well
[Re: MR_P_BODY]
#2754295
03/21/20 07:10 PM
03/21/20 07:10 PM
Dave_J
Auburn WA
Myself I wouldnt waste my time with dual inlets.. a 1/2" inlet is more than you need so why carry the extra weight and pluming.. just more possible leaks Edited my last post above. 1 single pickup, the bolt on pump cover one. Tests I read said that this pump "Cover Type" pickup with a standard volume pump will flow more oil than a stock pickup with a Melling high volume pump. The stock pickup is a huge bottle neck. I have seen some that are thick tube outside but small inside diameter. The biggest inside diameter ones I have seen are 1/2 inch inside until 1 inch from the pump and then necked down to that 3/8s pipe screw in.
