Re: Ring and Pinion quality scale
[Re: Moparmal]
#2754000
03/20/20 11:37 PM
03/20/20 11:37 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
I've always had the worst luck with Richmond. Wouldn't rank the rest but would say after doing many gear installs, I try for oem used or oem/nos gears above all else if possible.
[Re: INTMD8]
#2754007
03/21/20 12:39 AM
03/21/20 12:39 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Thx. I will be using 4.10 ratio so OEM may be tricky - glad to hear others have had the same Richmond issues.
[Re: Moparmal]
#2754013
03/21/20 01:10 AM
03/21/20 01:10 AM
INTMD8
Lake Villa Il
I have a Dana 60 and had a bit of a hard time finding a 4.10 as well. Ended up putting -wanted- ads on Dodgecharger.com and moparts and had what I needed right away.
(was much easier than watching ebay for a month)
[Re: dvw]
#2754147
03/21/20 12:13 PM
03/21/20 12:13 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
I've used Richmond US and Motive none with out some issue from time to time ( bridged pattern, Noisy) but only one failuer and that was in a 12bolt with way too much power and tire.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: dthemi]
#2754208
03/21/20 02:58 PM
03/21/20 02:58 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Nobody's gears are as good and as consistent as they once were. US Gear and Motive seem to be the best options now. Richmonds are awful. I've seen some failures of those over the past few years that just make you shake your head.
[Re: DoctorDiff]
#2754406
03/22/20 07:10 AM
03/22/20 07:10 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Richmond and Motive 742 casting gears are identical.
Other than the pinion spline count, Richmond and Motive 489 casting gears are identical.
They are both made in the same factory in Italy on the same machinery.
Motive's 9.5 gears look like jewelry next to a richmond. Are they made there as well?
[Re: dvw]
#2754447
03/22/20 10:08 AM
03/22/20 10:08 AM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Used a Motive street gear Dana 4.10 in my race car. It was quiet coasting with engine shut down. It lasted 400 passes before bending the teeth. The no name replacement set only went 125 passes before shattering pinion teeth. Car has been 1.25 60ft at 3350lbs. Now has a US Gear pro gear. Doug Wow, what is the rest of your combination?
[Re: 340Cuda]
#2754472
03/22/20 11:06 AM
03/22/20 11:06 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Used a Motive street gear Dana 4.10 in my race car. It was quiet coasting with engine shut down. It lasted 400 passes before bending the teeth. The no name replacement set only went 125 passes before shattering pinion teeth. Car has been 1.25 60ft at 3350lbs. Now has a US Gear pro gear. Doug Wow, what is the rest of your combination? There is a nice writeup about Doug's car on Dragzine I have used Motive gears on different rears and they all had a great pattern and were quiet on a few street cars I have done. A few more I have built are in drag cars so I don't know if they are quiet or not but they are 9 inch Ford rears and still getting beat on all season. I used the Summit Racing house brand gears when I had a 9" in my Savoy and they were the Italian gears made by Maserio ? They were 4.56 9-inch Ford gears and it was a very nice set and they were very quiet for 4.56's Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: DoctorDiff]
#2754562
03/22/20 01:18 PM
03/22/20 01:18 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would be surprised if they weren't. Most of the stuff I see is 9" and I've seen some ugly Richmonds the last few years. Broken (shattered) teeth. gears that look like someone took a disc grinder to the contact area. I assume these guys are putting actual gear lube in their rears.
