Broke my Sure-grip, need new one, which one? #2752638
03/16/20 07:41 PM
03/16/20 07:41 PM
Benton, IL.
DaveRS23 Online rolleyes OP
Special needs idiot
DaveRS23  Online Rolleyes OP
Special needs idiot
Benton, IL.
Well, I need to replace my 54 year old clutch Sure-Grip. A couple of spider gears are cracked as is the housing. I am leaning towards the Tru Track, but not sure. 3.91s in a 489 case. 295 MT Mickey Thompson drag radials. Mostly street, but some 1/8 mile king of street stuff. Started to go with a spool, but think I would rather have a Sure-Grip. The Eaton Tru Trac seems to run over $600. eek Is that what I need. Is there a better price out there for it?
Thank you!
Master, again and still
Re: Broke my Sure-grip, need new one, which one? [Re: DaveRS23] #2752639
03/16/20 07:42 PM
03/16/20 07:42 PM
Jamey Offline
Jamey  Offline
Doctor Diff sells new power locks if you want the same as what you were running. Not too bad on price either, believe they are under $400.
Re: Broke my Sure-grip, need new one, which one? [Re: Jamey] #2752642
03/16/20 07:51 PM
03/16/20 07:51 PM
Kirkland, Washington
Pacnorthcuda Offline
To Clarify; the Power Lock (Powr Lok) is a clutch type. The OP’s 489 could very well have been a cone type, which is vastly inferior to the clutch type.
Most would agree the clutch type IS the way to go, and Doc is the man. There are Eaton Tru Track fans, and some detractors.
I run a clutch type, wouldn’t have it any other way.
Re: Broke my Sure-grip, need new one, which one? [Re: DaveRS23] #2752644
03/16/20 07:58 PM
03/16/20 07:58 PM
W. Kentucky
justinp61 Online content
justinp61  Online Content
W. Kentucky
Spool.
Re: Broke my Sure-grip, need new one, which one? [Re: DaveRS23] #2752646
03/16/20 08:05 PM
03/16/20 08:05 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Used Tru-Tracks on the last 2 rear axles, one 8-3/4 and one Dana 60, no complaints on either. Will probably go with a spool on my Dana 60 because I am cheap. grin
The only Carbs I care about are under the hood!
Re: Broke my Sure-grip, need new one, which one? [Re: DaveRS23] #2752652
03/16/20 08:28 PM
03/16/20 08:28 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
As I said in the opening, I have the CLUTCH type. No way would a cone hold the drag radials. I have tried a couple of times to get a hold of Dr Diff, but to no avail. His website seems to say that he is out of both the Eaton and the Sure-Trac. And he says on his website that he has has trouble with the Eatons, so he recommends the cheaper Sure-Trac.
Not sure just what to do here which is why I asked for some input. If all else fails, I can spool it. It's just that I do park at shows and such, and those spools are a pain there.
Re: Broke my Sure-grip, need new one, which one? [Re: justinp61] #2752653
03/16/20 08:29 PM
03/16/20 08:29 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by justinp61
Spool.
X2.
Cheap, bulletproof and easy.
'63 Dodge 330
11.19 @ 121 mph
Re: Broke my Sure-grip, need new one, which one? [Re: DaveRS23] #2752660
03/16/20 08:48 PM
03/16/20 08:48 PM
I missed the word clutch. Got it.
What’s a “Sure-Trac” ???
Re: Broke my Sure-grip, need new one, which one? [Re: Pacnorthcuda] #2752662
03/16/20 08:52 PM
03/16/20 08:52 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
I don't know anything about it. It's just a unit that Dr Diff offers.
https://www.doctordiff.com/8-3-4-helical-gear-sure-grip-sure-trac.html
Re: Broke my Sure-grip, need new one, which one? [Re: DaveRS23] #2752664
03/16/20 09:00 PM
03/16/20 09:00 PM
Well that’s interesting. Looks new...like on the market for a year or two.
https://www.forabodiesonly.com/mopa...cal-gear-sure-grip-sure-trac-lsd.430216/
Also sounds like it might??? Be Docs own design???
If you google helical gear sure-trac there are other discussions. Too bad he doesn’t have the regular power locks for sale. I e seen em on eBay (new ones).
Re: Broke my Sure-grip, need new one, which one? [Re: Pacnorthcuda] #2752680
03/16/20 09:48 PM
03/16/20 09:48 PM
AndyF Offline
AndyF  Offline
Doctor Diff has several options on his website that look like they would work. I'd just pick whatever he recommends.
Re: Broke my Sure-grip, need new one, which one? [Re: Pacnorthcuda] #2752681
03/16/20 09:51 PM
03/16/20 09:51 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
Dr Diff doesn't show either one in stock, but both are available on ebag. Basically $600 +/- either way.
Re: Broke my Sure-grip, need new one, which one? [Re: Pacnorthcuda] #2752684
03/16/20 09:55 PM
03/16/20 09:55 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My 8.75" power-locks are in stock. See below:
https://www.doctordiff.com/8-3-4-clutch-type-sure-grip-powr-lok.html
Unfortunately, I don't know when the Sure-Tracs will be back in stock as the mfg has been dragging their feet.
If anyone needs to contact me, please E-mail. Phone calls are hit-or-miss this time of year. BTW, don't abbreviate "doctor" in my E-mail address. That is another guy. My E-mail address is doctordiff@gmail.com
Re: Broke my Sure-grip, need new one, which one? [Re: DoctorDiff] #2752689
03/16/20 10:08 PM
03/16/20 10:08 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
Okay, that email address has been my problem.
I guess you know that 'your' Sure-Tracs are available on the bag. They are higher which may be why they are still available.
https://www.ebay.com/itm/MOPAR-8-75-8-3-4-WORM-GEAR-POSI-FITS-ALL-CASES-TRU-TRAC-NEW-GREAT-DEAL/333454376488?hash=item4da36dfe28:g:01MAAOSwo-RdhQWR
Well, I can't get that link to work from here. But it appears to be the same unit.
Re: Broke my Sure-grip, need new one, which one? [Re: DaveRS23] #2752692
03/16/20 10:19 PM
03/16/20 10:19 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
There are a few floating around from re-sellers.
Re: Broke my Sure-grip, need new one, which one? [Re: DoctorDiff] #2752702
03/16/20 10:46 PM
03/16/20 10:46 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is that Sure Trac a Torsen based diff?
Kevin
Re: Broke my Sure-grip, need new one, which one? [Re: DaveRS23] #2752712
03/16/20 11:18 PM
03/16/20 11:18 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
My rebuilt cone paints 2 even stripes with slicks shruggy
Re: Broke my Sure-grip, need new one, which one? [Re: GTX MATT] #2752713
03/16/20 11:21 PM
03/16/20 11:21 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Spool.
You get the same amount of squealing and hopping as a Detroit Locker for less than 1/4 of the price.
Re: Broke my Sure-grip, need new one, which one? [Re: GTX MATT] #2752715
03/16/20 11:23 PM
03/16/20 11:23 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
I have ran cones a number of times. When traction is roughly equal on both sides, they work okay. But with sticky tires, when one side is compromised, like when track prep is marginal, they won't hold. In other words, a cone is not nearly as consistent as the clutch type.
Re: Broke my Sure-grip, need new one, which one? [Re: Twostick] #2752731
03/17/20 12:28 AM
03/17/20 12:28 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The Sure-Trac is a torque sensitive helical differential.
