Reuse Cam? #2752307
03/15/20 07:53 PM
03/15/20 07:53 PM
East Aurora (Buffalo) NY
RoadRunner Offline OP
Going through boxes and came across a camshaft. No lifters. Looks used. Can camshafts be reused if new lifters are purchased? Not sure I’d take the risk so may go in scrap pile. Have no idea of exact specs.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Reuse Cam? [Re: RoadRunner] #2752309
03/15/20 07:57 PM
03/15/20 07:57 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I reused one from my 318 to a 360 with new lifters. No problems yet.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Reuse Cam? [Re: RoadRunner] #2752328
03/15/20 08:37 PM
03/15/20 08:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
As long as it's in good shap, shouldn't be an problem with a new set of lifters. But then again how much is a new cam that you know the spec's on worth ?? beer
Re: Reuse Cam? [Re: TJP] #2752375
03/15/20 10:52 PM
03/15/20 10:52 PM
n.c.
geo. Offline
geo.  Offline
n.c.
I agree, wouldn't use it unless i could ID it with part number or actual lift measurement.
Are flat tappet cams too expensive?
Bet you could find a deal on a cam and lifter set.
Re: Reuse Cam? [Re: geo.] #2752411
03/16/20 01:10 AM
03/16/20 01:10 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Is works pretty good if you put the cam in the motor, each lifter in the motor with light oil, rotate the cam, they all spin, and the valve springs are not killer stiff, otherwise trash it.
Re: Reuse Cam? [Re: 4406bbl] #2752442
03/16/20 08:33 AM
03/16/20 08:33 AM
Thanks all. Given I have a couple of new cams on the shelf, no need to keep an unknown entity. Out it goes.
2023 Ford Mach 1
Re: Reuse Cam? [Re: RoadRunner] #2752452
03/16/20 09:06 AM
03/16/20 09:06 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I used a used cam once with new lifters. It lasted about 500 miles before it flattened two lobes. Never again for me.
Re: Reuse Cam? [Re: RoadRunner] #2752456
03/16/20 09:19 AM
03/16/20 09:19 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
A used cam is like a used condom....toss it
Re: Reuse Cam? [Re: DAYCLONA] #2752472
03/16/20 10:10 AM
03/16/20 10:10 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I never have known a problem with an used cam and new lifters. Of course as far the camshaft looks in good conditions. In fact, regular engine rebuild jobs never change the cam for a while they look good
if was wrong to install new lifters on an used cam, they weren't sold separatelly to replace them.
as far the specs... lift is easy. Rest with the degreing wheel
Re: Reuse Cam? [Re: NachoRT74] #2752489
03/16/20 10:55 AM
03/16/20 10:55 AM
Kirkland, Washington
Pacnorthcuda Offline
Remember there is a big difference between stock and high lift (stiff valve springs) in the older cars. You can probably get away with reusing a stocker (but to save $150???) but it would get progressively riskier are valve pressures go up.
Re: Reuse Cam? [Re: Pacnorthcuda] #2752651
03/16/20 08:22 PM
03/16/20 08:22 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have reused cams many times with new lifters or the same lifters if they were still in order with no problems. I have a MP 484 cam and lifters that has been in 4 different motors still running great.
The only Carbs I care about are under the hood!
Re: Reuse Cam? [Re: Azzkikrcuda] #2752659
03/16/20 08:46 PM
03/16/20 08:46 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I sold a comp 268h that had a ton of miles on it, but still looked great, to a guy for $20 and he put it in another engine with new lifters and it was fine.
For a mild cam it's likely ok. Huge cam = pass.
Re: Reuse Cam? [Re: RoadRunner] #2752679
03/16/20 09:43 PM
03/16/20 09:43 PM
E
earlymopar Offline
earlymopar  Offline
E
I had my re-ground for $75 and changed the lift and LSL profile in the process.
- EM
Re: Reuse Cam? [Re: Pacnorthcuda] #2753353
03/19/20 06:28 AM
03/19/20 06:28 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Its 2020 and the mere mention of a flat tappet cam makes me cringe. thats because of the decreased quality of the cam and lifters resulting in failures. the proper fix makes me cringe too. Roller cam conversion. $$$ But the failures are across all brands of engines and cannot be blamed on improper break in. Many guys who do it correct and they were met with a big fat failure due to crappy quality. Tony Defeo made a video recently ranting about his failure. He said no more flat tappets. If a guy who is a pro for doing things on the cheap has sworn off flat tappet cams and going roller then its a real problem.
Keep old mopars alive.
Re: Reuse Cam? [Re: 2boltmain] #2753429
03/19/20 11:59 AM
03/19/20 11:59 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
He is not alone, many people that do restorations will only use rollers, if not it is on the owners dime when the cam fails, not the shop eats the repair. A used 30-40 year old cam that looks good, and will spin all the lifters when turned by hand, might be better than new. I agree on break in, in the 70s we threw cams in everything, never went flat, now we are to dumb and are breaking it in wrong even with break in oil, I think the new parts are junk, and would worry more about the new lifters than a cam that can spin them.
Re: Reuse Cam? [Re: 4406bbl] #2753444
03/19/20 12:43 PM
03/19/20 12:43 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
I have used old cams many times. i always check my lifter bores for wear and lifter rotation first, i also hone the bores for a little crosshatch and to deburr if i feel i need to. i use good lifters and proper lube and make sure my engine fires instantly after prelube to do my break in. i have never lost a cam so far, now that may change, but if you make sure you have your spring pressures right and do all the steps you need too it really should be no issue.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
