15 inch rallye wheels
#2752017
03/14/20 10:50 PM
03/14/20 10:50 PM
340clone
What are some thoughts on original vs. reproduction 15 inch rallye wheels. Is it worth sourcing an original set over the reproductions?
Thanks!
Re: 15 inch rallye wheels
[Re: Neil]
#2752039
03/15/20 04:15 AM
03/15/20 04:15 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
I never have put side by side originals vs repros, but I can say got 15"x7" wheels from Specialty wheels and didn't have a problem
[Re: NachoRT74]
#2752062
03/15/20 09:35 AM
03/15/20 09:35 AM
Posts: 6,224 JERSEY
RJS
JERSEY
15x7 reproduction Rallyes are fine if your putting them on a 72 and up car. The reproductions were based on the Canada made wheel which came into play in 1972 model year.
The oval holes have a larger shrouding that once you know about it your eye will notice. Backspacing is the same as a Chrysler rim and you can even get custom backspacing. See me attachments and study the oval holes.
***note the wheel with 72 center cap is reproduction but has a correct brushed ring, the wheel with 71 center cap is original and has a correct brushed ring****
Ron
[Re: 340clone]
#2752085
03/15/20 10:48 AM
03/15/20 10:48 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks! I have original and repros on my toys, nothing really wrong with either unless your doing a numbers resto, the repros will need to be repainted as they just can't seem to powder coat them in the correct color, I always buy from Wheel Vintiques, never had an issue with fit or performance, no issue with trim ring/center cap original or repro or a mix of both being fitted/matched However if you run 15X7 originals with aftermarket front calipers, or rear disc set ups, the welds on originals are rather large beaded (sloppy) and often require dressing the weld or in some cases the caliper or both for fit
[Re: DAYCLONA]
#2752173
03/15/20 03:03 PM
03/15/20 03:03 PM
340clone
Thanks! I have original and repros on my toys, nothing really wrong with either unless your doing a numbers resto, the repros will need to be repainted as they just can't seem to powder coat them in the correct color, I always buy from Wheel Vintiques, never had an issue with fit or performance, no issue with trim ring/center cap original or repro or a mix of both being fitted/matched However if you run 15X7 originals with aftermarket front calipers, or rear disc set ups, the welds on originals are rather large beaded (sloppy) and often require dressing the weld or in some cases the caliper or both for fit Glad to hear that there is no problems mixing rings/center caps. That was going to be my next question! I have access to a set of each, but the originals are off of a '73 B-Body which are nice but need some cleaning up. The repros are basically like new. Whatever set I use I will just swap for my original 14's. I was just wondering if either set would add or subtract value depending on which was used. I am wanting to put a set on my '71 Challenger, which is stock but non-numbers.
[Re: 340clone]
#2752847
03/17/20 02:28 PM
03/17/20 02:28 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
The only issue I've had with the OE 15x7 rally rims is that they can break at the radius where the OD of the center cap meets.... causing fender damage. That was with Hoosier soft compound road racing tires. Although I love the looks, I personally avoid that design. Possibly, new aftermarket rims would not have that problem due to less years of usage on them vs OE wheels.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
