timing marker under engine #2751005
03/11/20 01:52 PM
03/11/20 01:52 PM
NC
P
psg Offline OP
psg  Offline OP
P
NC
I recently purchased an '86 360 D150 automatic. I decided to check the timing, and couldn't find the timing marker to match up with the damper. Eventually I found the marker plate with the magnetic tube on the underside of the engine. Is this someone's "fix?" I noticed someone on another forum mentioned when a steering pump was changed it altered the timing plate location because of a different model pump. Is this the likely issue or is this plate supposed to be on the underside of the car....? tnx psg
Faith in every footstep, faith in every mile
Re: timing marker under engine [Re: psg] #2751008
03/11/20 01:55 PM
03/11/20 01:55 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
do you know if motor is original to truck? seems like i remember vans having that setup as you could not get to/see timing tab.
Re: timing marker under engine [Re: psg] #2751056
03/11/20 04:48 PM
03/11/20 04:48 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I made a set-up similar to that for my Satellite because all of the turbocharger plumbing which made seeing the stock pointer impossible. Made the pointer from sheet metal,and it bolts under two of the front oil pan bolts. Re marked the balancer with new marks after verifying T.D.C., and it works fine. If you intend to use your current marker, DO NOT trust it until you verify the accuracy of the T.D.C. mark. If it is correct it will work as well as a pointer/mark on the top, just not as handy to get to.
Re: timing marker under engine [Re: rbkt65] #2751105
03/11/20 09:23 PM
03/11/20 09:23 PM
NC
P
psg Offline OP
psg  Offline OP
P
NC
I had presumed that it was but now I am wondering as there are a few other things in the engine compartment that had me wondering.
Re: timing marker under engine [Re: 67_Satellite] #2751106
03/11/20 09:25 PM
03/11/20 09:25 PM
NC
P
psg Offline OP
psg  Offline OP
P
NC
So do you lay on the floor... no lift... with the strobe to set the timing?
Re: timing marker under engine [Re: psg] #2751110
03/11/20 09:49 PM
03/11/20 09:49 PM
NC
P
psg Offline OP
psg  Offline OP
P
NC
I did a VIN check and the truck was delivered with a 360.
Re: timing marker under engine [Re: psg] #2751377
03/12/20 07:41 PM
03/12/20 07:41 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
But maybe not THAT 360
Re: timing marker under engine [Re: psg] #2751381
03/12/20 08:01 PM
03/12/20 08:01 PM
Yes. Jack it up and put it on stands, and use the light as usual from below. It's a pain once, but how often are you going to set it?
Re: timing marker under engine [Re: volaredon] #2751418
03/12/20 10:10 PM
03/12/20 10:10 PM
NC
P
psg Offline OP
psg  Offline OP
P
NC
Yeah, that is always a possibility.
Re: timing marker under engine [Re: 67_Satellite] #2751419
03/12/20 10:12 PM
03/12/20 10:12 PM
NC
P
psg Offline OP
psg  Offline OP
P
NC
Just wondering if there were other options. Tnx for the assistance and resource. psg up
Re: timing marker under engine [Re: psg] #2751543
03/13/20 01:12 PM
03/13/20 01:12 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
As far as I know your motor still has timing marks on the cover along with damper markings to time the motor. Might be hard to see but all the ones I have seen were doable,
Re: timing marker under engine [Re: NITROUSN] #2751555
03/13/20 01:47 PM
03/13/20 01:47 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've never seen the pickup tube mounted so it was accessible only from the bottom. Doesn't sound kosher. shruggy
Re: timing marker under engine [Re: 6PakBee] #2751932
03/14/20 05:25 PM
03/14/20 05:25 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
pic from my 1986 factory dodge truck service manual. sorry it is sideways. damn phone.
Re: timing marker under engine [Re: psg] #2751941
03/14/20 05:42 PM
03/14/20 05:42 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
That's for the magnetic pickup timing meter. It was needed with the smog pump and PS pump.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: timing marker under engine [Re: 3hundred] #2751988
03/14/20 08:16 PM
03/14/20 08:16 PM
N
N
Again there is still the timing cover marks and the balancer marks you can use to time it. Clean and mark them and there is a way to see them and time it. Best to have a helper and let him turn the distributor so you can keep your eyes on the marks. We did it all the time. Forget about the tin probe bracket and remove it and deep six it.
Re: timing marker under engine [Re: NITROUSN] #2752001
03/14/20 09:25 PM
03/14/20 09:25 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
someone asked earlier whether correct engine. that is why i posted pic. fsm shows equipped with both ways.
