AAR Cuda Leaf Springs #2750866
03/10/20 11:33 PM
03/10/20 11:33 PM
Pontiac, Illinois, USA
70-AAR-Cuda Offline OP
I'm looking for a source for a set of replacement OEM style Leaf Springs for my AAR Cuda does anyone have a source ?
Re: AAR Cuda Leaf Springs [Re: 70-AAR-Cuda] #2750899
03/11/20 07:32 AM
03/11/20 07:32 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
https://www.eatondetroitspring.com/application/aar-cuda/
Check with these folks, unsure if they have the first spring with the PN stamps but recal someone was making that as well.
Re: AAR Cuda Leaf Springs [Re: AAR#2] #2750900
03/11/20 07:36 AM
03/11/20 07:36 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
https://www.tonysparts.com/e-body-parts
Should have remembered it was Tony
Re: AAR Cuda Leaf Springs [Re: AAR#2] #2751010
03/11/20 02:12 PM
03/11/20 02:12 PM
DELAWARE
TONY_DAGOSTINO Online content
TONY_DAGOSTINO  Online Content
DELAWARE
thanks!
yes we offer the lower leafs for the b-body 440/hemi hd springs
the e-body hemi/440 hd springs
and the aar t/a lower leafs
just add to a new set of springs, like AAR mentioned, eaton is good to get them from as they were the original supplier to mopar
Re: AAR Cuda Leaf Springs [Re: AAR#2] #2751308
03/12/20 03:19 PM
03/12/20 03:19 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Eaton is the best. I have used them three times on a Bee, a GTX and now a 70 Challenger. You can order stock or a slightly different height.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
