Re: Centering rear axle in the car springs moved into the frame.
[Re: AndyF]
#2750626
03/09/20 11:25 PM
03/09/20 11:25 PM
Posts: 936 Deland, Florida
biff426
Deland, Florida
The pinion offset is correct I have measured that. Just trying to get the pinion in the correct spot and figured if I got the axle flanges equal distance from the frame rails it should put the pnion in the correct location right? It doesn’t look like the car was ever wrecked and I figured the frame was the best place to measure from..
[Re: biff426]
#2750629
03/09/20 11:33 PM
03/09/20 11:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You need to find the true centerline of the car then base it off that EDIT Also to think you have to have the pinion in the RIGHT place.. that can move to get the tires under the car ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: dvw]
#2750696
03/10/20 10:01 AM
03/10/20 10:01 AM
Posts: 19,708 north of coder
moparx
the quality control of these cars when new was atrocious at best. it was not uncommon to find the rear 3/8-1/2" or more off center compared to each quarter panel opening. as has already been said, square the axle to the centerline of the car, then move the rear side to side until it is equal to the frame rails. this will maximize the available tire/wheel combo space. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#2750702
03/10/20 10:26 AM
03/10/20 10:26 AM
Posts: 146 Missouri
randavis
Missouri
I'll second the QC issues. In December of 1973, I ordered a 74 Challenger. It was delivered in February 74.
A good friend of mine ran an alignment shop. I transferred the Crager SS wheels with G60-14's I had on my old car an took it to him for an alignment. He found the car had 1/4" longer wheel base on one side.
I took the car back to the dealer and complained. They called the zone manager to see what could be done. He approved the repair.
The car also had terrible finish on the rear roof seams. It was ordered without a vinyl top and the rear roof seams were plainly visible. They offered to install vinyl. I told them, if I wanted vinyl, I would have ordered it that way. Again, the zone manager approved a rework of the rear roof pillars. Even after the rework, it was still visible, just not as apparent. I restored the car a couple of years ago and the body man I used fixed the seams and now it looks good.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: dvw]
#2750716
03/10/20 11:26 AM
03/10/20 11:26 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Most body's are not on the true centerline. My way has been to center to outsides of the tires in the 1/4 panels. Dont be surprised if the axle measures off to one side more than the other. Centering it dead on may look like crap. As long as the axle is square to the centerline it bothers nothing. Doug ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Get the tires & wheels on the rear and center the tires in the wheelwell. Where the pinion ends up, it is what it is. If the pinion isn't centered, no one will see it and it won't matter anyway. If the wheels aren't centered, it'll look like crap and everyone will see it.
[Re: an8sec70cuda]
#2750735
03/10/20 12:31 PM
03/10/20 12:31 PM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I restored the car a couple of years ago and the body man I used fixed the seams and now it looks good. But it doesn't look "original" !!! I have never seen an e-body car with well-finished roof seems - and I was around when they were new!! The quality absolutely sucked ! It seems there were many fitment issues - as evidenced by the gobs of seam sealer. On my 69 RR one of the rear spring hanger attachment brackets was put in crooked - something next to impossible to fix without major time and effort. If I hung a spring in it, the end of the spring was outside the rear quarter !!
[Re: Stanton]
#2750738
03/10/20 12:48 PM
03/10/20 12:48 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I would for sure set it down on the tires before you weld the perches on. I measured mine off the rails and and one tire hit the leaf springs, thankfully I hadn't welded it all up yet. I got real scientific with it, my clearance was limited so I put the tires on and I have one crescent wrench handle between the sidewall and leaf springs on each side. This distance works well and nothing rubs, I have zero room to move either direction really. If you use this method make sure to use a standard crescent wrench and not a metric one! ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
68 Barracuda Formula S 340
[Re: moparx]
#2750769
03/10/20 02:54 PM
03/10/20 02:54 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
the quality control of these cars when new was atrocious at best. it was not uncommon to find the rear 3/8-1/2" or more off center compared to each quarter panel opening. as has already been said, square the axle to the centerline of the car, then move the rear side to side until it is equal to the frame rails. this will maximize the available tire/wheel combo space. My son's 68 Dart 270's 7 1/4 looked good with the steel wheels and 165/70 14's. Put the A body 8 3/4 in with 15 inch Cop car ralley's and 235/60 15's and it still looked 'KIND OF' ok but you could see the right tire was closer to the fender. Fast forward a couple years. We put in the spring hanger kit inside the frame. Added new spring perches exactly the same distance inboard from the old ones, leaving the old ones in place. Put some Foose wheels with 325/50 20's under and the right side tire has 3/8" clearance but the left side has 13/16" gap. Just 7/16 difference. So I used some string and cross Diag'ed the frame and it is not square by any means.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2750781
03/10/20 03:46 PM
03/10/20 03:46 PM
Posts: 1,613 westerly, ri. usa
440lebaron
westerly, ri. usa
most mopars driveshaft is off set to pass side, measure trans output shaft centerline framerail to framerail, put center of pinion same place. axle flanges will be were it ends up (non adjustable) set pinion angle with weight on ground then tack
gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
