A gentle reminder of why regular oil changes are important.. #2750228
03/08/20 06:43 PM
03/08/20 06:43 PM
Hamtramck, PA
Alaskan_TA Offline OP
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Ick!
On the bright side, no internal rust to be seen...... scope
1970 383 sludge 1.JPG1970 383 sludge 2.JPG1970 383 sludge 3.JPG1970 383 sludge 4.JPG
Re: A gentle reminder of why regular oil changes are important.. [Re: Alaskan_TA] #2750229
03/08/20 06:45 PM
03/08/20 06:45 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I dread looking inside my 51 218 flathead 6. Almost 70 years of non-detergent oil and a bypass filter. Not gonna be pretty.
Re: A gentle reminder of why regular oil changes are important.. [Re: Alaskan_TA] #2750231
03/08/20 07:06 PM
03/08/20 07:06 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Honestly, id much rather find that then a motor that was drained and sat on a concrete floof for 25 years.
That all will clean up nice.
STOP POTATO HATE!
Re: A gentle reminder of why regular oil changes are important.. [Re: Sniper] #2750235
03/08/20 07:15 PM
03/08/20 07:15 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
When I bought my '55 Plymouth, I changed the oil and it came out black and thick. I started it and idled it until it got hot, then I changed it again. I think I changed it about 6 times in the first few months, just to try and get as much gunk as possible out of the engine. The filter housing was hardened sludge up to the drain-back hole. Taking that off and digging what seemed like window putty out with a screwdriver made me feel better about the whole thing. Eventually, I replaced the feed and drain hard lines on the filter housing with braided AN lines so I could empty the filter when I do an oil change.
Re: A gentle reminder of why regular oil changes are important.. [Re: Mr PotatoHead] #2750236
03/08/20 07:17 PM
03/08/20 07:17 PM
tboomer Offline
tboomer  Offline
X2!
Re: A gentle reminder of why regular oil changes are important.. [Re: tboomer] #2750237
03/08/20 07:20 PM
03/08/20 07:20 PM
Guitar Jones Offline
You would be surprised how often I see this, and on fairly new cars.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: A gentle reminder of why regular oil changes are important.. [Re: Alaskan_TA] #2750248
03/08/20 07:49 PM
03/08/20 07:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
In 1976 my brother bought a new Chevy pickup with a 350. He changed the oil religiously every 3000 miles with Quaker State Delux 10-40. At 42000 miles it spun a rod bearing, the engine in the first post is clean compared to his. The rocker arms were working in sludge. IiRC that oil was a paraffin based.
Re: A gentle reminder of why regular oil changes are important.. [Re: justinp61] #2750282
03/08/20 09:32 PM
03/08/20 09:32 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My aunt had a 69 Olds Cutlass she insisted got Quaker State oil changes ever 6,000 miles. Around 50,000 I had to replace all the rocker stands. The motor was so sledged up, the rockers left an imprint in the crud stuck to the inside of the covers. I had to do the whole deal again at around 70,000. I finally convinced her she needed to quit using Quaker State, and she needed to change her oil at 2,000 miles instead of 6,000 miles. After following my advice, she did get over 100K miles out of that poor Olds before she traded it on something else. Gene
Re: A gentle reminder of why regular oil changes are important.. [Re: poorboy] #2750296
03/08/20 10:12 PM
03/08/20 10:12 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Saw that a lot in the 70s with regular oil changes of quaker state and z7 pennsoil. Oldsmobiles were the worst, cylinder head drains would plug. We used to pour 3 gallons of kerosene in them, run them, and change the oil to valvoline or texaco, never a problem after that.
Re: A gentle reminder of why regular oil changes are important.. [Re: 4406bbl] #2750339
03/09/20 07:47 AM
03/09/20 07:47 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Kerosene eek
That sure would LOOSEN IT UP but then it drops into pan THEN blocks the pickup eek eek
Re: A gentle reminder of why regular oil changes are important.. [Re: dOrk !] #2750344
03/09/20 08:04 AM
03/09/20 08:04 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Had a '72 318 with a spun rod bearing years ago that, when I pulled the intake, I was looking at an impression of the bottom of the intake. eek It looked like it had a valley pan the way B/RB engines do but it was in fact solid sludge. shock
I'm not 100% sure but I think the engine still had it's original oil filter on it and this was around '91......... shock
John
Re: A gentle reminder of why regular oil changes are important.. [Re: 4406bbl] #2750345
03/09/20 08:06 AM
03/09/20 08:06 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Ive seen this exact same thing happen to engines even with proper oil changes . The company I used to work at back in the 80s used nothing but Valvoline, And after pulling the valve covers on one truck and I couldn't see the rockers arms,
Ive never used Valvoline since
Re: A gentle reminder of why regular oil changes are important.. [Re: gtx6970] #2750376
03/09/20 09:35 AM
03/09/20 09:35 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I never saw that, maybe it was not the oil causing it. All my stuff had valvoline or phillips 66 and looked like new with 3000 mile oil changes. Cold weather state. Who knows?
Re: A gentle reminder of why regular oil changes are important.. [Re: dOrk !] #2750380
03/09/20 09:47 AM
03/09/20 09:47 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Kerosene eek
Never a problem, scrape out what you could, jack the front up on the rack to about a 30 degree angle, let it drain overnight, chunks came out. Never lost a motor, one olds went another 100,000 after that. 318s had an issue with the plate on the bottom of the intake, oil would coke on the intake after the heat riser stuck shut. I saw one so bad that you could not see the cam and the plate and 2 rivets were laying in the motor. Same deal, clean, kerosene and a few oil changes and it never quit till it went to the junkyard.
Re: A gentle reminder of why regular oil changes are important.. [Re: 4406bbl] #2750392
03/09/20 10:14 AM
03/09/20 10:14 AM
an8sec70cuda Offline
I remember rebuilding many cylinder heads that came in the shop that looked like they still had a valve cover on them. The mechanic had to dig out a hole to find the head bolt.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: A gentle reminder of why regular oil changes are important.. [Re: 4406bbl] #2750393
03/09/20 10:16 AM
03/09/20 10:16 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I wouldn't doubt that some oils would tend to leave more deposits than some others. But my personal experience is that the vehicle's daily operation is much more of an factor.
For instance, I began my Mopar experience by using the engines from retired police cars. Never have I pulled an ex-squad down that had those kind of deposits. And all of them had a ton of miles. But they had spent nearly all of their operational time at full operating temp.
But I have been into many low mileage engines with that kind of sludge. Most of them were primarily driven around town, running errands, stop and go from home to the store and back without the opportunity to fully warm up.
I have read that when oils are slightly heated and then allowed to cool, that the parafins in them tend to separate out and deposit. While getting the oil up to operating temp and kept that way for a sufficient amount of time, keeps the parafins suspended in the oil.
Modern oils resist that better than earlier oils, but sludging is still possible. And then engine design plays a role too. Think the 2.7 from 20 years ago. In other words, there are a lot of factors beyond simply the brand of oil that plays a role in engine deposits.
And although I haven't done it for 40 years or so, we used to flush engines with kerosene. I was actually taught it in auto mechanics class in high school.
twocents
Master, again and still
Re: A gentle reminder of why regular oil changes are important.. [Re: DaveRS23] #2750413
03/09/20 11:10 AM
03/09/20 11:10 AM
moparx Offline
moparx  Offline
always flushed with kerosene or diesel fuel back in the day on sludgy stuff.
even did it some on known good engines as preventative maintenance.
beer
Re: A gentle reminder of why regular oil changes are important.. [Re: DaveRS23] #2750422
03/09/20 11:42 AM
03/09/20 11:42 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
twocents
Makes sense, seems the people that had us change their oil never had a problem, same brand oil all the time. I wonder if using various brands would maybe cause the problem. They used to sell motor flush, but kerosene just flat worked every time.
Re: A gentle reminder of why regular oil changes are important.. [Re: 4406bbl] #2750469
03/09/20 01:38 PM
03/09/20 01:38 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Over the years I've seen several engines flushed with kerosene and none experienced any issues later.
The engine mentioned in my earlier post was in a daily driver, about a 20-25 mile each way to work. So it had plenty of time to warm up. Until recently I always used Havoline oil and my engines were always clean when taken apart. Like most oils I think it's been reformulated in recent years.
Re: A gentle reminder of why regular oil changes are important.. [Re: Alaskan_TA] #2750474
03/09/20 01:58 PM
03/09/20 01:58 PM
MA
BH27G1B Offline
BH27G1B  Offline
MA
Years ago I flushed out a tractor engine that had anti-freeze mixed in the oil. I ran it for a while, drained it, and it has been running great for years now. As a kid, I bought cheap Saffire motor oil and ran it in a Y block Ford, but that had oiling problems anyways. After that I have been using various weights of Valvoline with no problems at all, and I change oil often.
