Re: Headlight bulb UPgrade ? [Re: stumpy] #2749691
03/06/20 08:43 PM
03/06/20 08:43 PM
Florida STAYcation
dOc ! Offline OP
The village idiot's idiot
dOc !  Offline OP
Florida STAYcation
Originally Posted by stumpy
Try EBay for LED info. You don't have to buy there but you could get some ideas. Basically you need to know what bulbs your carrot van uses.
ESPECIALLY for the 200 vert .... those are kind of BUGER to get at
Re: Headlight bulb UPgrade ? [Re: dOc !] #2749774
03/07/20 09:22 AM
03/07/20 09:22 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I see a few suggestions for LED's, but how well do they work out in a 365 day driver when you live somewhere where you get frozen precipitation?
I've seen a number of comments online of how great LED's are, EXCEPT because they generate no heat, they won't stay clear in snow/frozen rain.
shruggy
John
Re: Headlight bulb UPgrade ? [Re: SattyNoCar] #2749823
03/07/20 12:30 PM
03/07/20 12:30 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Satty7 ... did a quickie search for the carrotvan... 10-12$ for a pair ??!!
Snow and frozen rain ? SOUNDS like that’s bummer climate to live in ! smoke
Re: Headlight bulb UPgrade ? [Re: dOc !] #2749882
03/07/20 02:31 PM
03/07/20 02:31 PM
GA
roadrunninMark Offline
GA
These won't fit your carrotvan or 200, but for older style 5 3/4" 4 headlight systems... What do you guys think about these? It says they do not come with instructions, so might take a little ingenuity to get them wired correctly? They might just plug right in too? I can't see the plug end. Price is pretty darn good for 4 LED glass headlights (unless it is chinese wonder$hit).... headlights on ebay
Re: Headlight bulb UPgrade ? [Re: roadrunninMark] #2749886
03/07/20 02:38 PM
03/07/20 02:38 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Is there a stock appearing LED replacement headlight for a 1970 Duster available now.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Headlight bulb UPgrade ? [Re: pittsburghracer] #2749903
03/07/20 03:36 PM
03/07/20 03:36 PM
GA
GA
Pit, these fit a Dodge D100, which shows the same as the 70 Duster on Rock auto list. So I believe these would work for you. Not exaclty OEM looking lens, but pretty close and not bad on the price..... https://www.ebay.com/itm/H6024-Head...0?hash=item4b1ae6c282:g:qUQAAOSwo8NcW1pp
Re: Headlight bulb UPgrade ? [Re: roadrunninMark] #2749910
03/07/20 04:07 PM
03/07/20 04:07 PM
PA.
"Little"John
"Little"John
PA.
Hey thank you Sir. It’s for a couple track only cars so it doesn’t have to look perfect. Heck honestly I only need a low beem to get through some of the dark pits. The led would be less battery drain I’m sure. Thank you very much.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
