Which Spark Plugs for Stealth Heads? #274871
04/02/09 09:43 AM
04/02/09 09:43 AM
Adelaide, SOUTH Australia
REDNICK Offline OP
REDNICK  Offline OP
Hi,
It might sound like a dumb question but......
what part number ( Champion or NGK) would I need for these ali heads?
Combo is 440-512 stroker, comp xe290 solid cam, 1.6 roller rockers, weiand single plane, holley 980 cfm ,headers and dual system. 4 sped car.
any starting point would be good
Nick
Re: Which Spark Plugs for Stealth Heads? [Re: REDNICK] #274872
04/02/09 11:56 AM
04/02/09 11:56 AM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
When I got mine..440 source sent me a set of Champion RC12YC. But I too would like to know what other brands cross reference..like maybe Accel, NGK, or Autolite?
Re: Which Spark Plugs for Stealth Heads? [Re: Dr-Dave2] #274873
04/02/09 12:03 PM
04/02/09 12:03 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
I'm running NGK FR5's. It's an extended tip, resistor plug in a fairly hot heat range. So far they are looking good (light tan color) being street driven with lots of idling and low speed cruising.
Re: Which Spark Plugs for Stealth Heads? [Re: Classof70Chally] #274874
04/02/09 02:54 PM
04/02/09 02:54 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
This site http://www.sparkplugs.com/ allows you to enter your part number and see all similar products by other manufactures.
Re: Which Spark Plugs for Stealth Heads? [Re: REDNICK] #274875
04/02/09 03:23 PM
04/02/09 03:23 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
NGK BCP5ES or BCP6ES. BCP6ES is a colder plug.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Which Spark Plugs for Stealth Heads? [Re: REDNICK] #274876
04/02/09 04:28 PM
04/02/09 04:28 PM
AndyF Offline
AndyF  Offline
For street just use the same plugs that later model Mopar engines came with. It is just a basic 3/4 reach plug. Used in a billion applications including almost all aftermarket cylinder heads.
Re: Which Spark Plugs for Stealth Heads? [Re: AndyF] #274877
04/02/09 05:12 PM
04/02/09 05:12 PM
GTXKen Offline
super gas
GTXKen  Offline
super gas
Denso Iridium plug 5303 IK16 $11.99
NGK Double Platinum 4045 PFR6A-11 $12.06
NGK Double Platinum 2097 BCPR5EP-11 $7.16
NGK Double Platinum 3350 BCPR6EP-11 $7.83
Splitfire Platinum spark plug TP392D TP392D $5.99
Autolite Racing series AR3924 AR3924 $3.61
Bosch Obsolete Plug, Click "More Info" For Replacement 7527 FR8DC+
Bosch Bosch Super Start Spark Plug 7816 FR9DC $2.39
Denso Traditional spark plug 3130 K16PR-U11 $2.39
NGK V-power spark plug 4043 ZFR4F-11 $2.64
NGK V-power spark plug 3686 FR45 $2.39
NGK V-power spark plug 3696 BKR6EY $2.39
NGK Obsolete Plug, Click "More Info" for Replacement 3783 BKR6ES
NGK V-power spark plug 2355 BKR5EY-11 $2.39
NGK V-power spark plug 2391 BKR5E-N-11 $2.39
NGK V-power spark plug 2441 BCPR5EY-11 $2.39
NGK Traditional spark plug 2460 BKR5ES $2.39
NGK V-power spark plug 2526 BKR5EYA-11 $2.39
NGK V-power spark plug 2756 BKR6E-11 $2.39
NGK Traditional spark plug 4298 BCPR7ER $6.21
NGK V-power spark plug 4421 BKR4E $2.39
NGK Traditional spark plug 2330 BCPR6ES $2.39
NGK V-power spark plug 5155 FR4 $2.39
NGK V-power spark plug 5165 ZFR5F $2.64
NGK Traditional spark plug 5553 BKR6ES-11 $2.39
NGK V-power spark plug 5584 ZFR5J-11 $2.64
NGK Traditional spark plug 6130 BCPR5ES $2.39
NGK Traditional spark plug 6696 BCPR5ES-11 $2.39
NGK Traditional spark plug 6779 BCPR6ES-11 $2.39
NGK V-power spark plug 6953 BKR5E-11 $2.39
NGK V-power spark plug 6962 BKR6E $2.39
NGK V-power spark plug 7373 FR5 $2.39
NGK V-power spark plug 7390 BKR5EY $2.39
NGK Traditional spark plug 7496 BCP5ES $2.39
NGK Multi-ground plug 2288 BKR6EK $5.19
NGK V-power spark plug 1148 BCPR5EY-N-11 $2.39
NGK V-power spark plug 1266 BCPR5EY $2.39
NGK V-power spark plug 1269 BCPR6E $2.39
NGK V-power spark plug 1273 BCPR5E-11 $2.39
Splitfire Spark plug SF392D SF392D $3.99
Re: Which Spark Plugs for Stealth Heads? [Re: GTXKen] #274878
06/29/09 08:45 AM
06/29/09 08:45 AM
WA 98043
thecarfarmer Offline
WA 98043
Just an FYI for everybody...
I put a set of NGKs (my preferred brand) in my stealths last week; the hex on the plug is partially obscured by the material of the cylinder head when the plug is seated. This makes it really easy for the socket to slip off when tightening 'em.
I hadn't noticed this initially, since I was staring straight at the ends of the plugs, reaching thru the fender.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Which Spark Plugs for Stealth Heads? [Re: Mick70RR] #274879
07/16/14 10:22 AM
07/16/14 10:22 AM
BeavisHQV Offline
BeavisHQV  Offline
5 years later. what sparks have been best. would like to use the ngk. but what heat range.
thx
Re: Which Spark Plugs for Stealth Heads? [Re: BeavisHQV] #274880
07/16/14 10:52 AM
07/16/14 10:52 AM
IF you know your compression ratio then call NGK tech line--live person nails the plug you will need--simple--easy as pie and they KNOW what to use--
