Valve spring retainer lock removal/installation tools? #2747856
02/29/20 08:35 PM
02/29/20 08:35 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
For some reason, once the valve spring is compressed, I always struggle getting the locks in and out of the retainers. My fat fingers don't fit in there too good. I've seen some special tools before that seem to make it easy, plus keep ones fingers out of the danger zone. But I can't remember what it was. I'm talking racing valve springs, not those tools for stock springs that you just tap with a hammer. Any recommendations?
Thanks,
Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Valve spring retainer lock removal/installation tools? [Re: Hemi_Joel] #2747864
02/29/20 09:03 PM
02/29/20 09:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just use a rubber mallet to loosen them then use a magnet to get them out and the magnet to put them in and a
small screw driver to get them off the magnet
wave
Re: Valve spring retainer lock removal/installation tools? [Re: MR_P_BODY] #2747870
02/29/20 09:15 PM
02/29/20 09:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Yup, this.
Plus a bunch of rags everywhere so nothing drops into the engine.
Re: Valve spring retainer lock removal/installation tools? [Re: topside] #2747880
02/29/20 09:55 PM
02/29/20 09:55 PM
Minnesota
Minnesota
up That's the way I've been doing it for years. I'm ready to switch over to the easy way. Especially for installing them. I'm looking for info and feedback on the specialty tools that are supposed to make it faster and easier. wrench
Re: Valve spring retainer lock removal/installation tools? [Re: Hemi_Joel] #2747903
02/29/20 11:11 PM
02/29/20 11:11 PM
I now always use a big (3.0 lb.) brass hammer to tap the edges of the retainers before trying to compress any springs, even with 75 lbs. on the seats or 325 lbs. on the seats on a roller cam head hammer up
I've seen other shops use a 1/2 inch drive 5/8 or 11/16 socket over the center of the valve stem and tap it with a big hammer also to loosen the keepers up, they both work scope
Re: Valve spring retainer lock removal/installation tools? [Re: Hemi_Joel] #2747963
03/01/20 10:35 AM
03/01/20 10:35 AM
montana
BANDIT Offline
BANDIT  Offline
montana
The LSM stuff is hard to beat, I’ve even used the on car tools on the bench just because the control of the spring “danger zone” is so much more secure. The one I have works on my -1’s and 572-13’s. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Valve spring retainer lock removal/installation tools? [Re: BANDIT] #2747990
03/01/20 12:12 PM
03/01/20 12:12 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would second that, LSM stuff is top notch and there is no fears of it coming loose.
68 Barracuda Formula S 340
Re: Valve spring retainer lock removal/installation tools? [Re: Bad340fish] #2748060
03/01/20 04:42 PM
03/01/20 04:42 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I like how the LSM gives you plenty of room to get my fingers in there to get the locks seated, I still use a small dab of grease to stick them to my finger so I don't loose them twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Valve spring retainer lock removal/installation tools? [Re: fourgearsavoy] #2748280
03/02/20 12:12 PM
03/02/20 12:12 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I use part of an LSM tool in the drill press.LSM does NOT make one for a hemi,but would be easy to do!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
