Valve spring retainer lock removal/installation tools?
#2747856
02/29/20 08:35 PM
02/29/20 08:35 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
For some reason, once the valve spring is compressed, I always struggle getting the locks in and out of the retainers. My fat fingers don't fit in there too good. I've seen some special tools before that seem to make it easy, plus keep ones fingers out of the danger zone. But I can't remember what it was. I'm talking racing valve springs, not those tools for stock springs that you just tap with a hammer. Any recommendations?
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Valve spring retainer lock removal/installation tools?
[Re: Hemi_Joel]
#2747903
02/29/20 11:11 PM
02/29/20 11:11 PM
Posts: 43,214 Bend,OR USA
Cab_Burge
I now always use a big (3.0 lb.) brass hammer to tap the edges of the retainers before trying to compress any springs, even with 75 lbs. on the seats or 325 lbs. on the seats on a roller cam head I've seen other shops use a 1/2 inch drive 5/8 or 11/16 socket over the center of the valve stem and tap it with a big hammer also to loosen the keepers up, they both work
[Re: Hemi_Joel]
#2747963
03/01/20 10:35 AM
03/01/20 10:35 AM
Posts: 422 montana
BANDIT
montana
The LSM stuff is hard to beat, I’ve even used the on car tools on the bench just because the control of the spring “danger zone” is so much more secure. The one I have works on my -1’s and 572-13’s. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#2747990
03/01/20 12:12 PM
03/01/20 12:12 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
The LSM stuff is hard to beat, I’ve even used the on car tools on the bench just because the control of the spring “danger zone” is so much more secure. The one I have works on my -1’s and 572-13’s. Jim I would second that, LSM stuff is top notch and there is no fears of it coming loose.
68 Barracuda Formula S 340
[Re: fourgearsavoy]
#2748280
03/02/20 12:12 PM
03/02/20 12:12 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I use part of an LSM tool in the drill press.LSM does NOT make one for a hemi,but would be easy to do!
