Hydraulic roller for 505" #2747113
02/27/20 03:07 PM
02/27/20 03:07 PM
portland, ct
Since1822 Offline OP
portland, ct
Looking for opinions on the roller cam that came in this 505" shortblock that I got with car. Pump gas motor with cnc stealth heads- cam is an older hughes grind: 236/242 duration .560/.570 lift 110 lsa installed at 107. Going in a street trim satellite, 3.91gears auto with 3000ish converter. I'm trying to decide whether to throw a solid in it or buy a set of roller lifters and run it. I am guessing it would run pretty good in a street car. RPM intake with nice 950ish carb
Re: Hydraulic roller for 505" [Re: Since1822] #2747135
02/27/20 04:57 PM
02/27/20 04:57 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
That is a great cam for the application you described. I would use PAC beehive springs part # PAC-1220. Good Luck on your build!!
Re: Hydraulic roller for 505" [Re: Since1822] #2747136
02/27/20 04:58 PM
02/27/20 04:58 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
That’s pretty small but you can always have it reground for just over 100 bucks. That would be a low rpm torque monster that could be driven. 👍
Re: Hydraulic roller for 505" [Re: viperblue72] #2747140
02/27/20 05:09 PM
02/27/20 05:09 PM
an8sec70cuda Offline
It ought to drive real nice on the street and be a torque monster, but it's a lot smaller than what I'd have wanted for a 500" motor. I'd pick something like that for a stock stroke street motor.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hydraulic roller for 505" [Re: an8sec70cuda] #2747148
02/27/20 05:33 PM
02/27/20 05:33 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I run a Howards hydraulic roller that is very similar in lift and duration. It makes for a great street car and is pretty quick to boot!
'63 Dodge 330
11.19 @ 121 mph
Re: Hydraulic roller for 505" [Re: GY3] #2747168
02/27/20 06:46 PM
02/27/20 06:46 PM
gregsdart Offline
gregsdart  Offline
I would run that cam and focus left over funds on optimizing traction. Since a street car seldom sees lots of rpm, torque becomes a great thing to have an excess of.
Re: Hydraulic roller for 505" [Re: Since1822] #2747192
02/27/20 08:25 PM
02/27/20 08:25 PM
AndyF Offline
AndyF  Offline
That should be a really nice street cam. The hyd roller that I have in my Coronet is roughly the same size but on 112 lobe centers for even less overlap. For your application I'd say that cam is a pretty good choice.
Re: Hydraulic roller for 505" [Re: AndyF] #2747196
02/27/20 08:37 PM
02/27/20 08:37 PM
portland, ct
portland, ct
This is great news. Andy, did you use the Comp lifters with the Coronet motor? If not, what do you suggest for this application? I called Hughes and they suggested using the Howards they sell. Thanks to all for the advice.
Re: Hydraulic roller for 505" [Re: Since1822] #2747216
02/27/20 09:53 PM
02/27/20 09:53 PM
AndyF Offline
AndyF  Offline
I used Gaterman lifters in my engine.
Re: Hydraulic roller for 505" [Re: AndyF] #2747220
02/27/20 10:05 PM
02/27/20 10:05 PM
portland, ct
portland, ct
thanks Andy. Just emailed them to find out where to purchase.
