Re: 727 rear clutch
[Re: eds dart]
#274696
04/02/09 09:01 AM
04/02/09 09:01 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
IIRC, it's a common deal to remove that wavey snap ring. I may be confused, the books I have are packed away right now...
Re: 727 rear clutch
[Re: eds dart]
#274699
04/02/09 03:11 PM
04/02/09 03:11 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
727's prior to '65 didn't use the wavy ring and spacer in the rear clutch, a single thick snap ring holds the Belleville in the drum. This snap ring has tabs at each side of the end gap where most clutch snap rings have a tab on one side and an angle-slice on the other side.
Somebody has swapped in earlier parts.
Re: 727 rear clutch
[Re: John_Kunkel]
#274701
04/03/09 08:08 AM
04/03/09 08:08 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
Thanks for clearing that up John , I forgot about the wavy snap ring used to hold the belleville in ![](/ubbthreads/images/graemlins/spank.gif)
