Re: Alum heads vs iron heads on street car [Re: lewtot184] #2746732
02/26/20 02:41 PM
02/26/20 02:41 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
As for the original post I think the hemi may lose a bit more thermally due to the massive chamber.
I'm having trouble finding it now but thought I read about a test on an ss/ah Hemi cast iron vs aluminum heads with the same port program and aluminum was down 40hp.
Could be wrong, that is just from memory, I'll keep looking for the info.
EDIT-
This is where I read that-
https://board.moparts.org/ubbthread...55708/re-aluminum-heads.html#Post1355708
Re: Alum heads vs iron heads on street car [Re: polyspheric] #2746738
02/26/20 02:57 PM
02/26/20 02:57 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Originally Posted by polyspheric
One reason why they are more knock tolerant is... less power. The heat loss is power not reaching the crankshaft.
This is why you do not remove carbon from the chamber and exhaust ports: it's a thermal barrier.
Back to back tests done on BBC 50 years ago: iron wins.
How does built up heat in the head get to the crankshaft? If both motors are maximized for their head material aluminum wins every time.
NOBODY fast runs iron heads unless rules of their class dictate they must.
Re: Alum heads vs iron heads on street car [Re: BobR] #2746744
02/26/20 03:15 PM
02/26/20 03:15 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I find this very interesting... I wanted to start with my cast iron heads... then later switch to aluminum in a about 2-years... but I was told that my pistons (-20 dish) dictated cast iron heads only because of the lower CR (~9.75:1). I've since installed the cast iron heads, and also cc'd chambers and cylinder... calculated the CR at 9.9:1
I'd still like to eventually swap to aluminum heads... per allowable racing class rules. Cast iron allows me to run in more classes and be more overall competitive, but giving up a little to the classes which allow aluminum heads.... weight is factor for me... more than engine power.
Re: Alum heads vs iron heads on street car [Re: fast68plymouth] #2746787
02/26/20 05:16 PM
02/26/20 05:16 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Originally Posted by fast68plymouth
The notion that you “need” more compression with aluminum heads has been tested at least once with a SBC, where you can buy heads that are the same in iron or aluminum........ and the results are that the power was the same.
I don't know that anyone said aluminum heads " need " more compression.
They ARE more tolerant of higher compression , and less likely to experience detonation.
As far as over thinking , I guess most of my thoughts are in taking weight off the front of the car.
Better handling is one claim , though few of us drive where that difference is really appreciable.
But less weight is still less weight.
I don't know that they are ever a bad idea , but that being said , I am looking at a set of J heads on my current project.
There is a certain pleasure to underthinking.
Re: Alum heads vs iron heads on street car [Re: tubtar] #2746802
02/26/20 05:54 PM
02/26/20 05:54 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The internet wisdom premise is...... if you changed from iron to aluminum heads, all else being equal, you’d lose power...... because the aluminum absorbed some power away.
And...... you’d have to up the CR for the aluminum headed combo to be equal to the iron head combo.
The test in the link I posted did what I feel is a pretty thorough test of that in a very “man on the street” type of build.
The difference in power was with the margin of repeatability for the dyno.
That’s using heads that are as close as possible to being the same, other than the material they’re made from.
In the case of what most people here are doing......if they’re going from iron to aluminum....... you’re almost never comparing equal heads.
In most cases, you’re replacing iron heads with better flowing aluminum heads(otherwise.....why are you changing the heads?).
It’s going to pretty hard to come up with some sort of “high performance” build combo where the better flowing aluminum heads get out powered by old iron heads.
Re: Alum heads vs iron heads on street car [Re: fast68plymouth] #2746805
02/26/20 05:58 PM
02/26/20 05:58 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I don't know of any mopar heads that are available in both materials that are identical architecture wise.
DART sells sbc heads in both iron and aluminum, but not for Mopars. Going back to back with those heads on a dyno on the same shortblock would tell you.
Re: Alum heads vs iron heads on street car [Re: Neil] #2746822
02/26/20 06:36 PM
02/26/20 06:36 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Were the old 440-C Indy heads the same as the 440-1?
'63 Dodge 330
11.19 @ 121 mph
Re: Alum heads vs iron heads on street car [Re: Neil] #2746825
02/26/20 06:49 PM
02/26/20 06:49 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Maybe the MP hemi heads?
Re: Alum heads vs iron heads on street car [Re: INTMD8] #2746827
02/26/20 06:53 PM
02/26/20 06:53 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Pretty sure those are Edelbrock castings with MP cast into them instead of Edelbrock.
Kevin
Re: Alum heads vs iron heads on street car [Re: Twostick] #2746831
02/26/20 07:10 PM
02/26/20 07:10 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Yes I thought Edelbrock made them but thought they were closer to the cast iron heads than their Victor heads, certainly could be mistaken on that but thought Victors had larger valves and ports.
Re: Alum heads vs iron heads on street car [Re: INTMD8] #2746851
02/26/20 08:04 PM
02/26/20 08:04 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Edelbrock says that Mopar would not allow any improvement.
Re: Alum heads vs iron heads on street car [Re: Hemi ragtop] #2746957
02/27/20 08:02 AM
02/27/20 08:02 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks for all the input guys. I’ve got two builds on the plans right now. The one with a 440 is a easy deal. He has more money to spend so custom pistons, 440 source alum heads and Cometic head gaskets are not a problem. CR will end up at 9.8 to 10 to one. It’s the budget 383 I’m building with off the shelf pistons, limited cam choices low CR right now. By the time I fix his 452 heads, I’m 70% there to 440 source alum heads. He is really tight on money. That’s the big deal. I may end up with seal power forged and cut some valve notches.
My alum heads vs iron head power question with all things being equal was from and SS/BA friend from years ago. In a 65 acid dipped car, he had problems keeping the front wheels on the ground, so weight transfer benefit was no help to him. Maybe the big chamber of the hemi was different.
Re: Alum heads vs iron heads on street car [Re: fastmark] #2747036
02/27/20 12:21 PM
02/27/20 12:21 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
70% of the way to the selling price? Or the price including shipping? Or the price, plus shipping, plus having them checked out?
Re: Alum heads vs iron heads on street car [Re: fast68plymouth] #2747052
02/27/20 12:57 PM
02/27/20 12:57 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Good point on adding everything up when making a comparison.
When I compared the 440Source Stealth heads to the Edelbrock E Streets, the E Streets came out cheaper due to the fact that you can get them from Summit or Jegs with free shipping and they usually have some kind of spend over $1000 and get $100 off sale. So for the same price or cheaper, you can get the E Streets which will flow a little better than the Stealths. Seems like the only reason to go with the Stealths these days would be if you want something you can paint and look stock. Or if your headers can deal with angled spark plugs, you can go with the ProMaxx heads which would be even cheaper than the E Streets.
Re: Alum heads vs iron heads on street car [Re: 67Satty] #2747081
02/27/20 01:58 PM
02/27/20 01:58 PM
So. Burlington, Vt.
So. Burlington, Vt.
The 84cc E streets have straight plug holes.
If the OPs budget 383 uses angle plug friendly headers, the 75cc E streets would certainly go a long way to upping the compression.
Re: Alum heads vs iron heads on street car [Re: fast68plymouth] #2747285
02/28/20 08:25 AM
02/28/20 08:25 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Quote
Well when you figure EVERYTHING, more like 50%. New bolts, better head gasket. He has cast iron manifolds and intake. I imagine I will end up with fixing the old 452. I can get him up to about 8.8 or 8.9 CR and use a smaller cam with about 218@.050 and survive. I may have to fly cut the pistons a little for clearance. Comp says their cam with a 110 centerline is ground with 4 degrees advance already. That’s as big as I dare get.
Re: Alum heads vs iron heads on street car [Re: fastmark] #2747316
02/28/20 10:31 AM
02/28/20 10:31 AM
So. Burlington, Vt.
So. Burlington, Vt.
I highly doubt there would be any clearance issues with a Comp 268H cam.
Re: Alum heads vs iron heads on street car [Re: fast68plymouth] #2747339
02/28/20 11:46 AM
02/28/20 11:46 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I got a similar dilemma with iron vs Alum heads.
I got a well built running mild built street 360 motor 9:1 mild cam Hyd cam with Hughes Stage 2 ported heads with SS valves. Its in a street cruiser.
I also got a spare set of built 305cfm Alum Hughes ported/coated heads sitting on the shelf.
Trying to figure out if its worth installing on a street motor, I like the weight weight loss, and not sure what I will ever do with them.
What to do?
Re: Alum heads vs iron heads on street car [Re: BobR] #2747594
02/28/20 11:28 PM
02/28/20 11:28 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Course its not my statement but I think he means the iron heads wont disapate the heat as much as aluminum so the heat exspansion in the cyl will be more with iron heads since they hold more heat and can add to more power pushing on the piston which will go to the crank of course.
Myself I agree with most that the difference is so minimal between iron and aluminum heads that many overthink it to much. As said most aluminum heads are newer and more modern with better combustion chambers and better flow then 50 year old iron heads. I have all the equipment to do the valve work on iron heads and set them up but to me its a no brainer in my street/strip car to go with the aluminum heads. And for the price of aluminum heads today most will spend as much paying someone to work iron heads for them anyway. And they do shave a little weight off the front end. Ron
