70 RR Turn signal switch? #2746708
02/26/20 01:47 PM
02/26/20 01:47 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Need a new switch....I ordered one from MegaParts..but after reading some posts.... it may not be correct? Will it work??
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR Turn signal switch? [Re: JMCFAN] #2746720
02/26/20 02:14 PM
02/26/20 02:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What switch did you order?
Re: 70 RR Turn signal switch? [Re: NITROUSN] #2746731
02/26/20 02:41 PM
02/26/20 02:41 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
https://www.megapartsusa.com/proddetail.asp?prod=MP%2DTSS804
Re: 70 RR Turn signal switch? [Re: JMCFAN] #2746736
02/26/20 02:49 PM
02/26/20 02:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Looks correct to me.
Re: 70 RR Turn signal switch? [Re: NITROUSN] #2747049
02/27/20 12:49 PM
02/27/20 12:49 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
One year only 1970 B & E body, the emergency switch you pushed IN, instead of pulling out !! This switch will work on your 70RR, but just not be "concours" correct because of the emergency switch . . .
Re: 70 RR Turn signal switch? [Re: a12rag] #2747982
03/01/20 11:35 AM
03/01/20 11:35 AM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
ALSO,you will probably have to file the black part down or widen the grove in the column,,the black part is to big
