Fuel Cell Questions
#2746215
02/24/20 08:34 PM
02/24/20 08:34 PM
Posts: 4,283 Danville, NH
Mopar_Mike
Danville, NH
So I am going to go with a fuel cell for my 67 Coronet RT and mount it in the trunk. All stock wiring, for the most part. I am looking at a plastic one with the foam and sending unit. From what I read, I need a sending unit that is 73-10 ohms. Will 70-10 work? that seems to be what is offered in that range. Also, I will need an outlet on the top of the tank for a vent and I am running a return line. Can I or should I run the return line also to the top (different outlet) or to one of the lower sump outlets. I only need one sump outlet for my pump. Thanks!
RS23L7 4-Speed
Re: Fuel Cell Questions
[Re: dOrk !]
#2746591
02/26/20 07:10 AM
02/26/20 07:10 AM
Mopar_Mike
Danville, NH
Any thoughts about a fuel sender for the gas gauge? I would like to keep the factory gauge. Thanks.
RS23L7 4-Speed
[Re: Mopar_Mike]
#2746638
02/26/20 10:45 AM
02/26/20 10:45 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Put your original unit back in but your gonna have to recalibrate it to the height of your tank... you will need to lengthen the float arm.. its easy but might take you a little time.. I did this on mine
[Re: Mopar_Mike]
#2746679
02/26/20 12:52 PM
02/26/20 12:52 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I used these guys to update my fuel system. They specialize in what you are doing and their tech is very helpful. https://www.harmonracingcells.com/
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
