Modern Radios #2745751
02/23/20 01:23 PM
02/23/20 01:23 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
What are ya'll using for sound. I want some modern features in a new radio that mounts in the original dash cutout. Plus, one that doesn't cost a body part. Some of the advertised ones are 600-800 bucks. Can't see that for a radio. It's going in my 64 Plymouth.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Modern Radios [Re: rattler] #2745762
02/23/20 02:11 PM
02/23/20 02:11 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Better take singing lessons. You can get yours converted for like 400 bucks. Then add for options. So 6 to 7 hundred is about the going rate.
Re: Modern Radios [Re: NITROUSN] #2745787
02/23/20 03:41 PM
02/23/20 03:41 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
couple of choices.
the right way is pay $$$ for a converted radio.
another cheap way out is install a factory dummy radio that doesn't work in the proper place. then mount a modern radio, preferably remote controlled, in a hidden location. a lot of people install it in the glove box.
perception is 90% of reality
Re: Modern Radios [Re: rattler] #2745810
02/23/20 05:13 PM
02/23/20 05:13 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have had good luck with Retro Sound radios. They are around $400.
The only Carbs I care about are under the hood!
Re: Modern Radios [Re: Mr T2U] #2745811
02/23/20 05:17 PM
02/23/20 05:17 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
On my 51 Plymouth I mounted a set of 5x7 speakers in the rear shelf with custom made adapters and mounted a bluetooth amp in the back to run them. I stream music from my smartphone. Less than $100 into it. My radio delete plate is unaffected adn everything is mounted under the rear package shelf.
Re: Modern Radios [Re: Sniper] #2745816
02/23/20 05:34 PM
02/23/20 05:34 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I installed one of these in my father-in-law's Li'l Red Express. He has a factory 8-track AM/FM and didn't want to hack it up.
With this amp in-line, the factory radio functions as normal and the amplifier itself interrupts and provides bluetooth support. May not do everything you want, but it's a cheap option
Bluetooth 2-channel pyle amp
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Modern Radios [Re: Mr T2U] #2745828
02/23/20 06:07 PM
02/23/20 06:07 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Glove box is out. That's where all the computers live now.
Re: Modern Radios [Re: rattler] #2746575
02/26/20 12:10 AM
02/26/20 12:10 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Get a new modern radio and use a custom "box" and mount it under the seat. Most now have Bluetooth, USB and aux inputs plus remote controls. My dash was already hacked so I have options.
