Air Grabber Vacuum Canister #2744462
02/19/20 12:01 AM
02/19/20 12:01 AM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
Can someone tell me what type of fastener Mopar used to mount the Air Grabber vacuum canister to the inner fender on a 71 RR ? I can't seem to find any information regarding what style,type,length & etc was used. If someone has a pic of what was used, that would be super fantastic. Thanks for any information that can be provided.
Re: Air Grabber Vacuum Canister [Re: GETX] #2744515
02/19/20 09:51 AM
02/19/20 09:51 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
It's a raised strap crimped to the can.
Re: Air Grabber Vacuum Canister [Re: RJS] #2744669
02/19/20 05:21 PM
02/19/20 05:21 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
Thanks for the response and pic, but I should have been more precise in my question. What I need to find out is what type of screw or bolt and what size was used to mount the canister to the fender ? The supplied pic appears to indicate a black phosphate bolt or phillips screw of some kind ? I can't make it out good enough to tell.
Re: Air Grabber Vacuum Canister [Re: GETX] #2744706
02/19/20 07:39 PM
02/19/20 07:39 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Hex head Black Phosphate self cutting type, don't know the size. You can check with Frank Badalson or RT Specialties
Ron
Re: Air Grabber Vacuum Canister [Re: RJS] #2744708
02/19/20 07:49 PM
02/19/20 07:49 PM
Mesa, Az
GETX Offline OP
GETX  Offline OP
Mesa, Az
Thank you sir ! I appreciate the response and advise,
Re: Air Grabber Vacuum Canister [Re: GETX] #2744783
02/19/20 10:27 PM
02/19/20 10:27 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
Mine have a 5/16" head.
