E Body front disc brakes #2744464
02/19/20 12:09 AM
02/19/20 12:09 AM
Brookeville Maryland
Hemivertible Offline OP
I am trying to convert my 1970 Dodge challenger front disc brakes to the larger 11.75 inch rotors. I changed my spindles out using a set from a 1973 challenger, but my problem is that when I mount the bearings and rotor The rotor will not slide on far enough to install the cotter pin in the outside opening of the spindle. I have checked several times and tried two different rotor manufacturers and can’t seem to figure out what I am doing wrong. The inner bearings are the 1 3/8” and slide all the way back on the spindle, they are Timken SET17s. It seems like the rotors don’t go back far enough because I mounted the caliper and it was pretty far to one side of the caliper brackets. Has anyone run into this situation before?
D73B731F-3600-46A9-8917-AA4228E05E51.jpeg32E222B8-B5C6-4BD4-8B40-B97D4710A2DB.jpeg6396253D-E122-43C3-B21E-5588266AE841.jpeg
Re: E Body front disc brakes [Re: Hemivertible] #2744471
02/19/20 01:23 AM
02/19/20 01:23 AM
AndyF Offline
AndyF  Offline
Those don't look like factory 11.75 rotors, they look more like a C body rotor with a longer nose. Could be junk Chinese rotors. When I was doing brake kits I used to keep an original factory 11.75 rotor on hand to use for checking dimensions. The rotors from China were garbage. The ones made in Mexico usually fit okay but were not high quality. The highest quality rotors came from Canada. Here is a picture of an 11.75 rotor that fits. Look at the shape and you'll see that it is very different than the rotor that you have.
Re: E Body front disc brakes [Re: AndyF] #2744485
02/19/20 06:17 AM
02/19/20 06:17 AM
BDW Online content
BDW  Online Content
I had similar issue, lip on the repo dust shield was too large.
Once I trimmed that down, it all fit.
Re: E Body front disc brakes [Re: BDW] #2744521
02/19/20 10:15 AM
02/19/20 10:15 AM
BDW,
That was it, you hit the nail on the head, I was re-using the 1970 dust shield from the 10.87 rotors and the new 11.75 rotors were hitting the center lip and not letting them slide all the way back!! Thanks, I was about to buy another set of inner bearings thinking the Timkens were too large. Crazy, I could not tell from spinning the rotor that it was not set all the way back on the bearing and was riding on the flange. Thanks again!
Re: E Body front disc brakes [Re: AndyF] #2744522
02/19/20 10:16 AM
02/19/20 10:16 AM
Thanks Andy, I was thinking the same thing and bought another set of rotors hoping that would solve my issue, but they did the same thing.
Re: E Body front disc brakes [Re: Hemivertible] #2744584
02/19/20 12:40 PM
02/19/20 12:40 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
As im doing the same to a 72 cuda and using dic-o -tec article. They call out dimensions of the spindle length. check article, and dimension and make sure yours are ok ?? My problem is (posted question in corning forum) I have a tall spindle and small caliper brackets. Check article for info. My help. Sure need help on mine Someone please read my question in other forum.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: E Body front disc brakes [Re: Hemivertible] #2744588
02/19/20 12:46 PM
02/19/20 12:46 PM
AndyF Offline
AndyF  Offline
Glad you got it fixed. I never thought of the shield as being the problem, I haven't seen that before. The factory shield should clear the factory rotors but anything is possible with offshore rotors. I've learned that the hard way several times.
Re: E Body front disc brakes [Re: AndyF] #2745100
02/21/20 01:10 AM
02/21/20 01:10 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That happens when '70-'72 splash shields are paired with '73 and newer rotors.
Re: E Body front disc brakes [Re: DoctorDiff] #2745102
02/21/20 01:16 AM
02/21/20 01:16 AM
AndyF Offline
AndyF  Offline
Ah, that was the problem. I guess I just assumed that the OP changed over to the late model shields when he installed the late model knuckles and rotors but evidently he didn't do that. Bad assumption on my part. (and his)
