Re: E Body front disc brakes
[Re: Hemivertible]
#2744471
02/19/20 01:23 AM
02/19/20 01:23 AM
Posts: 31,073 Oregon
AndyF
Those don't look like factory 11.75 rotors, they look more like a C body rotor with a longer nose. Could be junk Chinese rotors. When I was doing brake kits I used to keep an original factory 11.75 rotor on hand to use for checking dimensions. The rotors from China were garbage. The ones made in Mexico usually fit okay but were not high quality. The highest quality rotors came from Canada. Here is a picture of an 11.75 rotor that fits. Look at the shape and you'll see that it is very different than the rotor that you have.
[Re: Hemivertible]
#2744584
02/19/20 12:40 PM
02/19/20 12:40 PM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
As im doing the same to a 72 cuda and using dic-o -tec article. They call out dimensions of the spindle length. check article, and dimension and make sure yours are ok ?? My problem is (posted question in corning forum) I have a tall spindle and small caliper brackets. Check article for info. My help. Sure need help on mine Someone please read my question in other forum.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: DoctorDiff]
#2745102
02/21/20 01:16 AM
02/21/20 01:16 AM
AndyF
That happens when '70-'72 splash shields are paired with '73 and newer rotors. Ah, that was the problem. I guess I just assumed that the OP changed over to the late model shields when he installed the late model knuckles and rotors but evidently he didn't do that. Bad assumption on my part. (and his)
