E-BODY factory dash with rollcage. pics please
#2743303
02/15/20 07:52 PM
02/15/20 07:52 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
im getting a CM cage In my 70 cuda. looking for ideas for around the full factory dash, but tight to the Apillar, im aware the dash will need modified
Re: E-BODY factory dash with rollcage. pics please
[Re: mcat4321]
#2743339
02/15/20 09:29 PM
02/15/20 09:29 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
I just had a new CM cage completed in my 73 Cuda. The cage was ran close to the A pillar and dash but not thru the dash. At the cost of new dash pads I wasn't going to cut one.
I cannot figure out how to post images but if you PM me an email will gladly send you some photos.
Ok
[Re: mcat4321]
#2744314
02/18/20 03:48 PM
02/18/20 03:48 PM
Posts: 2,933 A shed in England
Tig
A shed in England
Here's a pic from a while ago when it was in the body shop. Top bar is a swing out bar legal to 8:50. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: T-bar]
#2744489
02/19/20 07:55 AM
02/19/20 07:55 AM
Posts: 10,044 MN
JERICOGTX
MN
If I ever did a E body cage, the bar would for sure hold tight to the A pillar, and go through the dash. It looks cleaner, and doesn't add a blind spot.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2744506
02/19/20 09:13 AM
02/19/20 09:13 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
If I ever did a E body cage, the bar would for sure hold tight to the A pillar, and go through the dash. It looks cleaner, and doesn't add a blind spot. Mine is an Alston's chassis works kit and the front bars do not go through the dash. It fit nice and was what I wanted, but I will redo the front bars at some point so they go through the dash. At the time I didn't want to cut the dash, but after dealing w/ it like it is, I wish I'd cut the crap out of it and tucked the bars up nice. Only pic I have here...
[Re: Tig]
#2744829
02/20/20 03:53 AM
02/20/20 03:53 AM
Tig
A shed in England
Here's a pic from a while ago when it was in the body shop. Top bar is a swing out bar legal to 8:50. HTH's Cage was installed 2001, we were running hi 10's back then and a friend hit the barrier and injured himself some but it could have been worse. We then upgraded to a full cage. Knowing what I know now I'd do it differently. It would be Chrome moly for a start and I'd go through a glass replica dash (Dash pad is mint bar one tiny crack). Cage would tightly follow the body lines best we coulld without compromising strength. Thought about doing it a while ago but the price of chrome moly put it out of reach when the car already certs to 8.50.
[Re: Tig]
#2747705
02/29/20 11:52 AM
02/29/20 11:52 AM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
The only pics I have on my comp. My dash was destroyed from the Az sun so I didn't mind cutting it up. Cage was done by a member here.
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
