Page 2 of 3 1 2 3
Re: Mechanical roller lifter [Re: fast68plymouth] #2746472
02/25/20 03:29 PM
02/25/20 03:29 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Ya it's odd cuz these are like my old crane rollers. No holes or notches in the lifter body. Just nice and smooth.. The only place fluid could go would be to the roller
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Mechanical roller lifter [Re: an8sec70cuda] #2746474
02/25/20 03:34 PM
02/25/20 03:34 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Originally Posted by an8sec70cuda
If you want a good durable lifter, go w/ the Iskys w/ the bushings. I have the old style Isky Red Zones w/ needle bearings and they've been flawless. Bought them in 2006 before the EZ Roll option was available.
Another small detail on the Redzone lifters,,,,,they hit the thicker lifter bore on the megablock down
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Mechanical roller lifter [Re: HOTMOPR] #2746476
02/25/20 03:43 PM
02/25/20 03:43 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If there are no notches or holes in the body, then they don’t have pushrod oiling.
Or pressurized axle oiling either.
Re: Mechanical roller lifter [Re: fast68plymouth] #2746482
02/25/20 04:20 PM
02/25/20 04:20 PM
hemi-itis Offline
hemi-itis  Offline
Those Morel lifters look promising work
Re: Mechanical roller lifter [Re: hemi-itis] #2746553
02/25/20 08:54 PM
02/25/20 08:54 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I am following this thread closely, I am building a Mega block for a customer now that has always run a solid flat tappet cam but wants to go to a solid roller cam this time. The Isky Red Zone lifters are on the short list for now. What part of the lifter is hitting the lifter bore? I am assuming the link bar? Is it because the lifter is too short? Any other things to be concerned about? Also what advantage is the AMC lifter over the Mopar(besides the pin oiling)?
Thanks, Brian
Re: Mechanical roller lifter [Re: '72CudaRacer] #2746583
02/26/20 02:11 AM
02/26/20 02:11 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
here they are
Re: Mechanical roller lifter [Re: HOTMOPR] #2746668
02/26/20 11:19 AM
02/26/20 11:19 AM
hemi-itis Offline
hemi-itis  Offline
That's kinda what the Red Zones looked like when I bought them,,,,,no pressurized oil into the lifter body.
Re: Mechanical roller lifter [Re: hemi-itis] #2746684
02/26/20 12:02 PM
02/26/20 12:02 PM
Missouri
galen Offline
galen  Offline
Missouri
I do not know if anyone has run into it. I tried the Morels same body in the pictures in an unbushed world block and I could not build any oil pressure due to the oil band cutouts on the side. Leaked by terrible at full lift. No problem with the comps I ended up putting back. On another note I had Isky rebuild a set of needle bearing redzones and had them converted from needles to bushings a couple of years back. BB Chevy application with oil band but worth checking for mopar. Cant remember the cost but it wasn't terrible.
Re: Mechanical roller lifter [Re: galen] #2746688
02/26/20 12:14 PM
02/26/20 12:14 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Was the oil band cutout dropping below or protruding above the lifter bore?
Re: Mechanical roller lifter [Re: INTMD8] #2746698
02/26/20 12:35 PM
02/26/20 12:35 PM
Missouri
galen Offline
galen  Offline
Missouri
[The world block I had came with a small machined undercut at the top of the lifter bores. It leaked top side at full lift .420 lobe lift. Leaking so bad at top didn't check bottom of bores. I found it prelubing could not build pressure and pulled the valley cover..I wish I had took pictures. Sold the morels to a member on here. May have just been a fluke deal with my block. Purchased it new from indy back in 08. Mock yours up and prelube it before you put it in just to make sure. I was curious if anyone else ran into it.
Re: Mechanical roller lifter [Re: galen] #2746705
02/26/20 12:43 PM
02/26/20 12:43 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Interesting, thanks for the info.
I'll be running slightly less lobe lift but I will make sure the oil window doesn't make it past the lifter bore in either direction. Thought if it was close on the top I could have the cam ground with a slightly smaller base circle. (assuming there was room for it to drop down in the bore)
Re: Mechanical roller lifter [Re: INTMD8] #2746709
02/26/20 12:47 PM
02/26/20 12:47 PM
Missouri
galen Offline
galen  Offline
Missouri
I could not see the cutout at the top but it was close enough it leaked past.
Re: Mechanical roller lifter [Re: galen] #2747388
02/28/20 01:21 PM
02/28/20 01:21 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Fwiw I went back and forth re 861 vs 829. At .690 lift and an unbushed world block I am deferring to Jonathan Martin of Comp and using the 829. Pin oiling and reasonable cost. The isky and morel are great but I can’t afford either. Comp is not rebuilding anything according th him
Re: Mechanical roller lifter [Re: Wirenut] #2749928
03/07/20 04:51 PM
03/07/20 04:51 PM
WNY
Moparrob68 Offline
Moparrob68  Offline
WNY
Just wanted to chime in with a few more lessons I learned the hard way about building a BME/World aluminum Hemi.I had a coolant leak into the valley apparently because the sleeves can "settle" in the block. While removing the lifters to retorque the valley studs I found several worn rollers.The original build a few years ago used the Barton
"Ultimate" flat tappet cam and tool steel lifters.After proper break-in with single springs and BR oil the Hemi ran great for about 2 months then flattened half the lobes.
Hemi build #2 I used a Bullet custom roller cam and Crower Enduramax pressure fed bushed roller lifters with Manton pushrods and Stage V rockers hoping my valve train problems would be a thing of the past.The 3940LB Coronet ran great, 9.85@138mph on pump gas for 1 1/2 summers until I found the worn lifters.Long story short, while Thought I had purchased the must durable lifters I could get, on further inspection I found that because these lifters are semi solid body and use a feed hole that is 90* from the roller oil feed rather than an oil band. Measuring from cam lobe to the 0.030 oil hole in the lifter bore bushing I found that it never lines up with the hole in the lifter so the roller bushings were running dry. I contacted Crower to see if an oil slot could be machined in the lifter and they said there isn't enough room. Sso now I have to spend another $1K on a custom LS tall body 0.903 needle bearing lifters with machined oil groove and have my pushrods shortened 0.250. Crower said roller bushings require at least 0.060 oil feed and that full synthetic oil allows the roller to skid instead of roll. They recommend a 50/50 blend. So on to Hemi build #3. Hope this long winded story helps someone.
Re: Mechanical roller lifter [Re: Moparrob68] #2750041
03/08/20 07:43 AM
03/08/20 07:43 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Why can't you open the oil hole in the bushing and groove the bushing from that hole up/down that would intersect the bushing? I've run synthetic with Isky Red Zone bushed for nearly 5 years over 400 pases. 310/805 pressure. still going.
Doug
Re: Mechanical roller lifter [Re: Moparrob68] #2750088
03/08/20 10:47 AM
03/08/20 10:47 AM
So. Burlington, Vt.
So. Burlington, Vt.
My question is...... where is the edm feed hole for the bearing located in this lifter?
What was the lifter to bore clearance?
Re: Mechanical roller lifter [Re: fast68plymouth] #2750092
03/08/20 11:05 AM
03/08/20 11:05 AM
So. Burlington, Vt.
So. Burlington, Vt.
This is from a set of Comp 87019’s.
Which is the same as an 892, but without pushrod oiling.
(The 892 is actually for use in a Chevy with .904 lifters, as the oil feed hole to the pushrod is in the wrong location for a Mopar.)
The AMC lifter, 861-16, has the same edm oil hole to the bearing as the 87019(illustrated with the drill bit), but also has the correctly positioned oil feed hole if one wanted pushrod oiling.
If you wanted oiling to the bearing, but didn’t want the pushrod oiling, and didn’t need the offsets....... you could buy 16 pieces of 87016C-1, and 8 pieces of 829-L link bars.
If you buy the 861-16 AMC lifters, you’ll also need to buy the 8 pieces of 829-L link bars.
The pushrod seat heights for the 87019 and 861 are the same, which is .120 higher in the body than the “normal” BB Mopar lifter......the 829(no oil band, no edm oiling to the bearing, no pushrod oiling).
What I’m not certain of is if the oil band length and position is the same between the 87019 and the 861.
If someone has an 861 out of the motor, maybe they could measure from the bottom of the wheel to the bottom and top of the oil band.
The bottom of the band on the 87019 is 1.100” from the bottom of the wheel, and is about .310” tall/wide.
Re: Mechanical roller lifter [Re: fast68plymouth] #2750119
03/08/20 11:48 AM
03/08/20 11:48 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
If someone has an 861 out of the motor, maybe they could measure from the bottom of the wheel to the bottom and top of the oil band. [/quote]
iagree
Dwayne I am using the 87016C -1 lifters that you prescribed for my Hemi back in 2011, and I have no complaints. I am using the World aluminum block with Stage V heads and rockers, Smith Bros push rods are not oiled.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Mechanical roller lifter [Re: Wirenut] #2750142
03/08/20 12:48 PM
03/08/20 12:48 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
829’s do not have pressurized axle oiling.
Just inspect yours for yourself......... how does the pressurized supply in the oil gallery get fed directly to the bearing?
Re: Mechanical roller lifter [Re: fast68plymouth] #2750239
03/08/20 06:24 PM
03/08/20 06:24 PM
AndyF Offline
AndyF  Offline
I ran into this a couple of times where Comp published information saying the 829 provided oil to the bearing but it doesn't. I think someone at Comp just messed up and got their part numbers confused. The issue is that then people read that info and believe it and then other folks don't know what to believe.
Page 2 of 3 1 2 3
