LH thread wheel stud for 70 Cuda 440 #2744020
02/17/20 07:52 PM
02/17/20 07:52 PM
Alabama
David1971 Offline OP
Alabama
When I purchased my 70 U-code Cuda, it came with 2 broken wheel studs on the drivers-side rear axle. I prefer to keep the left-hand threaded studs, as I want to maintain the original configuration. Plus, I have a new set of Mopar LH lugs. Looking at the Chrysler Parts Catalog, I am trying to determine which part number I need.
Re: LH thread wheel stud for 70 Cuda 440 [Re: David1971] #2744027
02/17/20 07:59 PM
02/17/20 07:59 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
2070159
Re: LH thread wheel stud for 70 Cuda 440 [Re: 44D6PAKCUDA] #2744036
02/17/20 08:13 PM
02/17/20 08:13 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Or try to find Dorman 610-104 , left had rear
Good luck though . Been discontinued for several years now. Not easy to find
Re: LH thread wheel stud for 70 Cuda 440 [Re: gtx6970] #2744098
02/17/20 10:41 PM
02/17/20 10:41 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Cleaning out parts and I came across these. I have 2 each left hand threaded studs of the sizes you see. These are the last 4 that I have. Will either of these work for you? The shorter ones are used but good. The longer ones are new. PM me
Terry
Re: LH thread wheel stud for 70 Cuda 440 [Re: 71vert340] #2744108
02/17/20 11:21 PM
02/17/20 11:21 PM
Alabama
Alabama
I took this picture last year while measuring the brake shoe. The head appears to match the shorter stud. I need to measure the length of the stud and check for a head marking.
Re: LH thread wheel stud for 70 Cuda 440 [Re: David1971] #2744128
02/18/20 12:03 AM
02/18/20 12:03 AM
MD
floyd Offline
floyd  Offline
MD
I think the shorter ones are right. I’ve got a couple used ones you can have as well. I’ll get some pics and measurements tomorrow.
Re: LH thread wheel stud for 70 Cuda 440 [Re: 71vert340] #2744216
02/18/20 11:13 AM
02/18/20 11:13 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Terry
Top one is rear
Bottom one is front disc brake rotor
Re: LH thread wheel stud for 70 Cuda 440 [Re: gtx6970] #2744245
02/18/20 12:35 PM
02/18/20 12:35 PM
MD
floyd Offline
floyd  Offline
MD
Extra rears. Yours if you want ‘em
Re: LH thread wheel stud for 70 Cuda 440 [Re: floyd] #2744426
02/18/20 09:11 PM
02/18/20 09:11 PM
Alabama
Alabama
I removed one of the broken studs today. I took some measurements of both the broken stud and threaded shank of one of the good studs. Then I thought about grabbing my Mitutoyo Dial Caliper. I had enough clearance to measure a good stud from head to tip. I got 1 3/4 inches exactly and that backs up what I got by combining the measurements I took earlier.
Re: LH thread wheel stud for 70 Cuda 440 [Re: David1971] #2744510
02/19/20 09:27 AM
02/19/20 09:27 AM
an8sec70cuda Offline
Looks like the ones Floyd offered you will work.
I was under the impression that 1970 models all got RH thread studs. My '70 'cuda and a '70 road runner I used to own both had RH studs on the driver's side when I got them. So unless they are late build cars, they had been changed prior to me owning them?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: LH thread wheel stud for 70 Cuda 440 [Re: an8sec70cuda] #2744624
02/19/20 02:34 PM
02/19/20 02:34 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
yes, they must have been changed
1970 LH & RH
1971 all RH
Re: LH thread wheel stud for 70 Cuda 440 [Re: 6bblgt] #2744648
02/19/20 03:56 PM
02/19/20 03:56 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
My very late 70 'cuda (7-30) has LH-RH studs.
Re: LH thread wheel stud for 70 Cuda 440 [Re: David1971] #2770795
05/03/20 02:05 PM
05/03/20 02:05 PM
Orange California
O
Ozzy Offline
Ozzy  Offline
O
Orange California
Hi I’m Ozzy just purchased my first challenger 1970, was going to try and give it a brake job and started off braking 3 studs off fan
I didn’t know about the left handed studs lol
Does any one have 3 LH ones for sale?
Would hate to change it if that’s how it’s stock
Re: LH thread wheel stud for 70 Cuda 440 [Re: formula_s] #2770873
05/03/20 06:18 PM
05/03/20 06:18 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Welcome Ozzy. That's a tough way to learn about the LH threads for a wheel stud. When I work on any Mopar 1970 or before, I have learned to check the LH studs before removing the wheel. Typically, the original studs would have a L or an R stamped on the end of the stud. Many of the LH ones have been changed, but not all. I hope you find some, otherwise, change them to RH. ALso, if you keep the LH studs, let the shop replacing your tires know of the studs or they may do the same thing you did.
Terry
Re: LH thread wheel stud for 70 Cuda 440 [Re: Ozzy] #2770940
05/03/20 09:29 PM
05/03/20 09:29 PM
Alabama
Alabama
I just checked the Apex AutoSports website and they still show the E-Body LH rear drum studs to be "out of stock". I would give them a call and ask if and when they expect to replenish their inventory.
David
Here is the link: http://www.apexautosports.com/store/
Re: LH thread wheel stud for 70 Cuda 440 [Re: David1971] #2771073
05/04/20 12:04 PM
05/04/20 12:04 PM
moparx Online content
moparx  Online Content
welcome to the board ozzy ! up
if you can knock out the remaining part of one of those broken studs to measure the knurl size, then get an overall length of the stud, i may be able to fix you up.
i have three used left hand studs left, and if they match yours, i'll send them to you gratis.
beer
Re: LH thread wheel stud for 70 Cuda 440 [Re: moparx] #2851033
11/24/20 06:35 PM
11/24/20 06:35 PM
NC
steves-cars Offline
steves-cars  Offline
NC
I just found this thread. Does anyone have LH thread studs for a front disc wheel? I need 5 but would take whatever anyone has. I think it's P/N 2944702 or maybe 3461816.
Re: LH thread wheel stud for 70 Cuda 440 [Re: steves-cars] #2851304
11/25/20 10:53 AM
11/25/20 10:53 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I likely have these LH studs....provide the critical dimensions and I will check my stock. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: LH thread wheel stud for 70 Cuda 440 [Re: 70gtx440dana] #2851657
11/26/20 02:29 AM
11/26/20 02:29 AM
I may have some also, front and rear up
Not gratis but not expensive either scope
Re: LH thread wheel stud for 70 Cuda 440 [Re: 71vert340] #2851706
11/26/20 09:59 AM
11/26/20 09:59 AM
Alabama
Alabama
Terry
As a follow-up to my original post: Back in February, I received the 2 used studs (the shorter ones) from Terry. They are an exact match to the remaining 3 studs on my 70 EF8 Cuda. A big "thank you" to Terry.
David
