Re: LH thread wheel stud for 70 Cuda 440
[Re: David1971]
#2744128
02/18/20 12:03 AM
02/18/20 12:03 AM
Posts: 4,114 MD
floyd
MD
I think the shorter ones are right. I’ve got a couple used ones you can have as well. I’ll get some pics and measurements tomorrow.
[Re: 71vert340]
#2744216
02/18/20 11:13 AM
02/18/20 11:13 AM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
Cleaning out parts and I came across these. I have 2 each left hand threaded studs of the sizes you see. These are the last 4 that I have. Will either of these work for you? The shorter ones are used but good. The longer ones are new. PM me Terry Top one is rear Bottom one is front disc brake rotor
[Re: David1971]
#2744510
02/19/20 09:27 AM
02/19/20 09:27 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Looks like the ones Floyd offered you will work.
I was under the impression that 1970 models all got RH thread studs. My '70 'cuda and a '70 road runner I used to own both had RH studs on the driver's side when I got them. So unless they are late build cars, they had been changed prior to me owning them?
[Re: David1971]
#2770795
05/03/20 02:05 PM
05/03/20 02:05 PM
Posts: 3 Orange California
Ozzy
Orange California
Hi I’m Ozzy just purchased my first challenger 1970, was going to try and give it a brake job and started off braking 3 studs off I didn’t know about the left handed studs lol Does any one have 3 LH ones for sale? Would hate to change it if that’s how it’s stock Thanks
[Re: Ozzy]
#2770940
05/03/20 09:29 PM
05/03/20 09:29 PM
Posts: 203 Alabama
David1971
Alabama
I just checked the Apex AutoSports website and they still show the E-Body LH rear drum studs to be "out of stock". I would give them a call and ask if and when they expect to replenish their inventory. David Here is the link: http://www.apexautosports.com/store/
[Re: steves-cars]
#2851304
11/25/20 10:53 AM
11/25/20 10:53 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I likely have these LH studs....provide the critical dimensions and I will check my stock. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#2851657
11/26/20 02:29 AM
11/26/20 02:29 AM
Posts: 43,115 Bend,OR USA
Cab_Burge
I likely have these LH studs....provide the critical dimensions and I will check my stock. Joe I may have some also, front and rear Not gratis but not expensive either
[Re: 71vert340]
#2851706
11/26/20 09:59 AM
11/26/20 09:59 AM
Posts: 203 Alabama
David1971
Alabama
Cleaning out parts and I came across these. I have 2 each left hand threaded studs of the sizes you see. These are the last 4 that I have. Will either of these work for you? The shorter ones are used but good. The longer ones are new. PM me Terry As a follow-up to my original post: Back in February, I received the 2 used studs (the shorter ones) from Terry. They are an exact match to the remaining 3 studs on my 70 EF8 Cuda. A big "thank you" to Terry. David
