Building a hand made tunnel for a hemi #2742689
02/13/20 10:42 PM
02/13/20 10:42 PM
edmonton alberta canada
500dart Offline OP
500dart  Offline OP
I,m am building a hand made tunnel for a 572 hemi . I am trying to maximize it , plenum volume , runner taper ,round runner vs square runners . What is the best aluminium alloy to build it from. I have 3100 lbs dart . I red line it at 7500 rpm. The convertor flashes to about 5700 rpm . I am currently running a indy tunnel ram with 2 850 cfm quick fuel carbs .
Re: Building a hand made tunnel for a hemi [Re: 500dart] #2742746
02/14/20 08:54 AM
02/14/20 08:54 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
3003 aluminium. I have a buddy building his own right now and he is having the runners done by Swartz out of Kansas.
Re: Building a hand made tunnel for a hemi [Re: 500dart] #2742785
02/14/20 10:41 AM
02/14/20 10:41 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
I am currently working on one for a modern hemi, I used 6061-T6 alloy as I did not do any forming, 3003 would be a better choice if you are going to form your runners.
I found the Tech info on Swartz website very helpful: http://www.swartzracingmanifolds.com/tech/index.htm
Re: Building a hand made tunnel for a hemi [Re: 500dart] #2742952
02/14/20 07:43 PM
02/14/20 07:43 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Look at the SS Cudas and Darts basically tunnel rams and they work. Incorporate lid spacers to tune for size of engine. But realistically it’ll be like throwing rocks at a moving train blindfolded. You might hit it eventually.
Re: Building a hand made tunnel for a hemi [Re: 496 A-body] #2742958
02/14/20 07:58 PM
02/14/20 07:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
How far apart are the runner angles from the port downdraft angles?
Any pictures of the final runner entry shape into the plenum?
Boffin Emeritus
Re: Building a hand made tunnel for a hemi [Re: polyspheric] #2742966
02/14/20 08:20 PM
02/14/20 08:20 PM
500dart Offline OP
500dart  Offline OP
I have not started on the build yet only in planning stages but debating on round runners vs square runners and taper rate.
Re: Building a hand made tunnel for a hemi [Re: 500dart] #2743282
02/15/20 06:55 PM
02/15/20 06:55 PM
AndyF Offline
AndyF  Offline
Start with a copy of PipeMax
Re: Building a hand made tunnel for a hemi [Re: 500dart] #2743302
02/15/20 07:45 PM
02/15/20 07:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A tall rectangular plenum runner entry is more difficult to improve with a radius, bell mouth etc. (which should extend above the floor for maximum CFM).
There is also a theory that the plenum cross-sectional area just inside the TB air entry should be considerably larger than the area after the last cylinders (linear taper or exponential? IDK), and the plenum should extend significantly beyond them (at least 1 entry diameter).
It appears from the pictures that your runner angle is more horizontal than your port centerline. IIRC unless you know better, closer alignment is preferred, but that may require a "horseshoe" runner (as seen in cross section across the valley) with curved legs.
Boffin Emeritus
Re: Building a hand made tunnel for a hemi [Re: polyspheric] #2743324
02/15/20 08:56 PM
02/15/20 08:56 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Agree with all of the above.
I realize the gen 3 pics are not from the OP, but the above info should all be applied to the gen2 from the OP.
A cross section of a gen 3 head shows the port entry angle. The pics (from the angle taken) look like the port entrance angle may be less than ideal.
Re: Building a hand made tunnel for a hemi [Re: AndyF] #2743826
02/17/20 03:00 AM
02/17/20 03:00 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
This is great advice
http://www.maxracesoftware.com/PIPE395.htm
Alan Jones
