E85
#2741212
02/09/20 01:11 PM
02/09/20 01:11 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
How much compression ratio will E85 support? How large a fuel cell do you streeters have in the trunk??
Re: E85
[Re: hemi-itis]
#2741224
02/09/20 01:39 PM
02/09/20 01:39 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
Fwiw, I've ran many 10-1 static CR LS engines at 25-30psi boost on E85.
Re: E85
[Re: INTMD8]
#2741228
02/09/20 01:47 PM
02/09/20 01:47 PM
hemi-itis
Fwiw, I've ran many 10-1 static CR LS engines at 25-30psi boost on E85. WOW!! More boost than I will ever see.Do these charts work the same for all types of boost be it roots,centrifical or turbo?? ![work work](/ubbthreads/images/graemlins/custom/work.gif)
Re: E85
[Re: 67_Satellite]
#2741250
02/09/20 03:19 PM
02/09/20 03:19 PM
hemi-itis
20 gallon cell. Have flirted with 17 lbs. without problems other than traction. How many mile do you get out of a 20 gallon cell with normal occasional street beatings ![work work](/ubbthreads/images/graemlins/custom/work.gif) I'm swaying and wondering why I have been to thick headed............
Re: E85
[Re: hemi-itis]
#2741260
02/09/20 03:54 PM
02/09/20 03:54 PM
INTMD8
Lake Villa Il
Really I think the chart is more of a general guideline as it isn't just manifold pressure vs static compression ratio that comes into play, there are a ton of other important variables.
You could have a few differences just comparing 2 turbo combinations to say the chart can't reflect all turbo combinations the same.
Re: E85
[Re: hemi-itis]
#2741266
02/09/20 04:14 PM
02/09/20 04:14 PM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
Only really checked once. Got 11-12 m.p.g. just driving normal highway speeds with minimal" spirited" (a.k.a. wife on board) driving. This was carbureted on 470 c.i. 9.9:1 compression ratio by the way.
Re: E85
[Re: tubtar]
#2741346
02/09/20 07:36 PM
02/09/20 07:36 PM
Superfreak
Superfreak
I would run E85 in a heart beat if we could get it here.
Re: E85
[Re: hemi-itis]
#2741414
02/09/20 10:27 PM
02/09/20 10:27 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
My current bracket motor(400 block stroked 4.300 with 4.375 bore) has right at 15.0 to 1 compression, ran it all last year on the local pump E85 that checks to be between E86 up to E89 % depending on which jug it came out of and how long I had that fuel sitting in the jugs ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) I have five 5.5 gallon plastic fuel jugs, some had fuel left ln them form the year before ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) I bought 8 gallons of E98 from Wal Mart late last year and I'm going to try and mix it with my local pump E85 so I get E89 or E90 all the time ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) I'm hoping that by having the same ratio percentage I can get a good handle on the tune up and make it go as fast as I can ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
Re: E85
[Re: Cab_Burge]
#2741448
02/10/20 12:15 AM
02/10/20 12:15 AM
hemi-itis
I don't see myself needing more than 15 lbs of boost and maybe 10 lbs to reach my legal cert. Pro Systems is providing a "booster" for my carbs to improve my lean spike at the hit condition.If it does the job I will be gold,,,,,,,,if not I need to be E85 THUMPED!! The legal limit is 8,50 so I'm a little over a 1/2 second away ![smoke smoke](/ubbthreads/images/graemlins/custom/smoke.gif)
