Ring clearance in piston #2737662
01/29/20 12:02 PM
01/29/20 12:02 PM
fredericksburg,va
cudaman1969 Online sleepy OP
cudaman1969  Online Sleepy OP
fredericksburg,va
1-16 rings, what clearance in the piston? My ring measures .0625. .001-2?
Re: Ring clearance in piston [Re: cudaman1969] #2737683
01/29/20 12:31 PM
01/29/20 12:31 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
IIRC, .001 to .002" falls in the "acceptable" range. Not supposed to be any tighter, though.
I checked the clearance on my last rebuild w/ some Total Seal rings and they were close to .002"; had a set of Mahle on hand that tightened that up about .0005", so I used the Mahles.
Re: Ring clearance in piston [Re: cudaman1969] #2737726
01/29/20 02:05 PM
01/29/20 02:05 PM
Tighter is better than to loose up ..001 minimum at room temps. on all rings twocents
Check the back clearances also, shim that if needed. I like .003 to .008 below the piston edges press all the way into the gorooves on those back clearances scope
Re: Ring clearance in piston [Re: Cab_Burge] #2737737
01/29/20 02:22 PM
01/29/20 02:22 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Ive always been under the impression that anything over .0015 is no so good tsk
Re: Ring clearance in piston [Re: dOc !] #2737757
01/29/20 03:09 PM
01/29/20 03:09 PM
fredericksburg,va
fredericksburg,va
My cutting tool i made is .067 so what you’re saying is I need it down to .064 ring being .0625? I’ll grind some more.
Re: Ring clearance in piston [Re: dOc !] #2737902
01/29/20 10:25 PM
01/29/20 10:25 PM
It is interesting to take the pistons your going to use and install and check one set of rings on the side clearances at room temps and the stick them into a oven 250F for 10 to 20 minutes and see how much they change on those clearances heated up a little scope grin
Re: Ring clearance in piston [Re: cudaman1969] #2737963
01/30/20 03:03 AM
01/30/20 03:03 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Cudaman1969, could you clarify your "cutting tool", not sure what you mean by this? Thanks
Re: Ring clearance in piston [Re: wyoming] #2738039
01/30/20 11:35 AM
01/30/20 11:35 AM
fredericksburg,va
fredericksburg,va
Tried to take pic of cutter but still learning. I’m cutting a 1/16 ring into the dykes ring spot, Ross said not a problem doing, one came out fine (test piston, have ten)
Re: Ring clearance in piston [Re: cudaman1969] #2738044
01/30/20 11:52 AM
01/30/20 11:52 AM
BradH Offline
BradH  Offline
I know 40 years ago that's how custom ring grooves were done, but the way pistons are manufactured today creates much smoother, flatter, and more consistent surface finishes for the rings to seal against.
Is this for a competition engine? If so, are new pistons w/ the ring lands put where you want them not in the budget?
Re: Ring clearance in piston [Re: BradH] #2738064
01/30/20 12:29 PM
01/30/20 12:29 PM
fredericksburg,va
fredericksburg,va
Street engine, $200 for all brand new right deck height bore and compression, and so easy a cave man can do it. No offense but really how much do you think it will matter if there’s a microscopic imperfection in the ring land even in a race engine? If your chasing numbers I could see but a street-occasional strip car?
Re: Ring clearance in piston [Re: cudaman1969] #2741189
02/09/20 12:34 PM
02/09/20 12:34 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
.0015"-.002" axial/vertical clearance is where a 1/16 ring with a bevel on the upper inner corner will work best. With gas ports it would work best in the .0008" axial/vertical clearance range.
Re: Ring clearance in piston [Re: LSP] #2741239
02/09/20 02:45 PM
02/09/20 02:45 PM
fredericksburg,va
fredericksburg,va
That’s what I’m shooting for thanks, No gas ports
