Re: Ring clearance in piston
[Re: cudaman1969]
#2737726
01/29/20 02:05 PM
01/29/20 02:05 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
Tighter is better than to loose ..001 minimum at room temps. on all rings Check the back clearances also, shim that if needed. I like .003 to .008 below the piston edges press all the way into the gorooves on those back clearances
