Vibration in 3rd gear only (A833)
#2741090
02/08/20 10:05 PM
02/08/20 10:05 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I'm gradually debugging my Dart 451, A833, 3.91 8-3/4. I've discovered a strange vibration only in 3rd gear. Doesn't seem to matter what engine RPM or driveshaft RPM is. At a given road speed, shifting out of 3rd to either 2nd or 4th makes the vibration stop. Cruises without vibrating in 4th at 60 mph (~3000 rpm). I dialed-in the Lakewood with offset dowels. It does not seem to change with accel or decel. Smooth in 1st, 2nd and 4th (straight-through, this is not the OD trans). This worries me because I'm thinking it may be a countershaft bearing problem... but then why doesn't it do it worse in the first two gears? Possibly shifter adjustment or a shift rod hitting the tunnel in 3rd? Any thoughts?
Re: Vibration in 3rd gear only (A833)
[Re: MO_PA]
#2741146
02/09/20 10:16 AM
02/09/20 10:16 AM
Posts: 6,250 nowhere
Sniper
nowhere
Adjust the shifter, the procedure is simple. While in neutral an 1/8 drill bit should pass through the alignment holes in the shifter. Pretty sure that's a 1/4" not an 1/8".
[Re: TJP]
#2741409
02/09/20 10:11 PM
02/09/20 10:11 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
[ Might want to verify the shifter stops aren't mis-adjusted as well if they're present Loosen the lock nuts, if your shifter has those stops before and back off the lock bolts before adjusting the shifter linkage with 1/4 inch alignment pin in place, the stops can be causing issues you wouldn't think of
[Re: DrCharles]
#2741498
02/10/20 10:23 AM
02/10/20 10:23 AM
Posts: 8,257 fredericksburg,va
cudaman1969
fredericksburg,va
Those little roller bearings between the main shaft and input. Think about it, more deflection at that “joint” in third gear than second or first. Other possibilities, bad teeth on gear or cluster or wrong ratio gear. Take out time and I'm afraid
