Re: Enamel over lacquer?
[Re: mopars4ever]
#274055
04/01/09 05:12 PM
04/01/09 05:12 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
Yikes good thought, I might have to get some alcohol out, and then find something to clean the parts off good before I try to repaint them.
[Re: SportF]
#274059
04/02/09 08:44 AM
04/02/09 08:44 AM
Posts: 1,572 Jacksonville Florida
elitecustombody
If you think it is fish eye, clean the area with the strongest soap like super clean and then maybe alcohol and wipe down with pre-clean or thinner of some type. Then test. If you have some dents, try some body filler. If you haven't ever used it, its pretty easy to work with in small areas. Just make sure you get the "mix with hardener type" and not the air dry stuff. If you have plastic stuff, use the plastic type paint over it. Give it a try,, it will be fun.
you can do it a few different routes, prep the surface ,clean it and apply few coats of waterborne sealer, another way is to strip the old finish off,prep and apply few coats of good primer ,then paint,
I think the main reason you're having this problem is because you're hosing on the paint,you have to do it in thin coats and let it dry before applying another coat,try first few coats just dusting it
