440 pad #2739893
02/05/20 10:52 AM
02/05/20 10:52 AM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
I come across this. What's it mean?
Re: 440 pad [Re: 440727] #2739901
02/05/20 11:22 AM
02/05/20 11:22 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
There's good info HERE on block stampings and casting #s.
Also appears that some shop that goes by SSRE did some work on it at some point... shruggy
Re: 440 pad [Re: BradH] #2739924
02/05/20 12:22 PM
02/05/20 12:22 PM
AndyF Offline
AndyF  Offline
I bought a 426W block once that said MATT LENT on the pad. I asked the guy what that stamping was. He said, oh, that is my name.
Re: 440 pad [Re: AndyF] #2739987
02/05/20 02:15 PM
02/05/20 02:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
SSRE:
SS Racing Engines?
Super Stock Racing Engines?
Might be worth a Google search as it appears they numbered it and may be able to tell you something about it.
Re: 440 pad [Re: topside] #2740051
02/05/20 05:36 PM
02/05/20 05:36 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Re: 440 pad [Re: tubtar] #2740059
02/05/20 05:56 PM
02/05/20 05:56 PM
BradH Offline
BradH  Offline
Scott Shafiroff?
Steve Schmidt?
Stanley Steamer?
tonguue
Re: 440 pad [Re: BradH] #2740260
02/06/20 10:49 AM
02/06/20 10:49 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
I once had a set of TA heads marked “Petty Enterprises shrt trk “. I got screwed out of them by a friend. They were good flowing heads.
Re: 440 pad [Re: fastmark] #2740262
02/06/20 10:54 AM
02/06/20 10:54 AM
an8sec70cuda Offline
In case you didn't know...that's a '67 HP 440 block assembled August 25th out of a '67 car. Not sure if you were only asking about the "SSRE" part or not.
The "SSRE" is just some shop that did work on it sometime in the past.
CHIP
'06 GMC 2500HD LBZ Duramax
