Re: Can't shorten aluminum driveshaft?
[Re: 408strokerdart]
#273951
04/01/09 02:56 PM
04/01/09 02:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Never heard of such a thing cant see why you couldnt have it shortened multiple times if you have the material
[Re: DRDart]
#273958
04/01/09 03:33 PM
04/01/09 03:33 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Is it welded or bonded???
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#273960
04/01/09 04:43 PM
04/01/09 04:43 PM
Posts: 3,456 Out West
408strokerdart
Out West
Welded.
#273961
04/01/09 04:44 PM
04/01/09 04:44 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
I am getting an aluminum driveshaft shortened two inches tommorow. No concerns were raised by the driveline shop.
76 Duster
work in progress
[Re: DRDart]
#273962
04/01/09 04:51 PM
04/01/09 04:51 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
I cannot see the logic in this either. I just wanted to get others opinions here. If it was a sales pitch, then it doesn't work when everyone elses comparable shafts are $200 less than yours across the board.
well no need to be like that now just trying to share info??? you don't even know what my drive shaft is so how can it be comparable
Good luck with your situation
I think he was refering to the driveline shop's product with the "yours". Their's is $200 more than everyone elses, not your's.
At least, that's how I read it.
[Re: G_bob]
#273963
04/01/09 05:06 PM
04/01/09 05:06 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Apparently, the bonded ones cant be shortened, an experienced chassis guy over here tried welding one and it wouldn't take, he said that Mark Williams were not very forthcoming with the type of alloy they are made from. I have got a welded one which i'm having shortened, so i'm interested in the outcome here. Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
#273965
04/01/09 07:05 PM
04/01/09 07:05 PM
Posts: 4,209 New York
polyspheric
New York
Now I'm confused. I can understand why the staff was told to say "it can't be done", because of legal issues, etc. If the ends are deeply inserted and mechanically locked (spline/flute) in the tube before welding I'd think it would be a nightmare to try to un-do or re-do this.
But.. why would a weld cutting only the tube itself not be possible? Can't be strength - if you move down the tube 6" so the area hasn't been heated at all, a simple sleeve or stub insert makes the new joint far stronger than the original tube with only a few ounces lost.
Boffin Emeritus
[Re: deaks]
#273966
04/01/09 11:49 PM
04/01/09 11:49 PM
408strokerdart
Out West
It is their welded version and the tube is clearly marked 6061 T6 aluminum. I am sure that the tube has a short register in it to maintain concentricity and then is welded. I don't believe that it can't be shortened. It might be cost prohibitive to do, but not possible?
Anyone need a shaft for a 727/Dana 60 111" A-body?
Guess I will post up in the classifides and get a new one on order.
#273967
04/02/09 12:10 AM
04/02/09 12:10 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Dont give up yet! The only problem I see with shortening a shaft is the amount of change in the length. Under a 1/2" may not be possible because of the previous welds width that needs to be cut out to get to fresh tube. mike
[Re: Sport440]
#273968
04/02/09 12:36 AM
04/02/09 12:36 AM
G_bob
Riverside, Ca
If the need to shorten it is caused by just the thickness of the mid-plate, that is probably the case.
