Can't shorten aluminum driveshaft? #273949
04/01/09 02:48 PM
04/01/09 02:48 PM
Out West
408strokerdart Offline OP
Out West
I found out that my aluminum driveshaft is to long now that I added a thick mid plate and was going to just send it back to Mark Williams to be shortened. They said they can't shorten aluminum drive shafts??? I know I should have asked, but can anyone here tell me what the reason might possibly be that they can't shorten it?
Guess I will just have to sell what I have and get another then. Someone will get another screaming deal in the parts section.
Re: Can't shorten aluminum driveshaft? [Re: 408strokerdart] #273950
04/01/09 02:51 PM
04/01/09 02:51 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
As far as I have been told you can shorten them once but after that you need a new one for strength & reliability which gets expensive
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg 1966 Charger 1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
Re: Can't shorten aluminum driveshaft? [Re: 408strokerdart] #273951
04/01/09 02:56 PM
04/01/09 02:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Never heard of such a thing cant see why
you couldnt have it shortened multiple times if you
have the material
Re: Can't shorten aluminum driveshaft? [Re: DRDart] #273952
04/01/09 02:56 PM
04/01/09 02:56 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Call Dynatech or Inland Empire and get a second opinion.
I'm Gumby dammit!
Re: Can't shorten aluminum driveshaft? [Re: MR_P_BODY] #273953
04/01/09 03:00 PM
04/01/09 03:00 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
have the material
They said that it weakens the aluminum or it could just be a 700.00 sales pitch But I could see the logic in that though
Re: Can't shorten aluminum driveshaft? [Re: DRDart] #273954
04/01/09 03:09 PM
04/01/09 03:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If that was the case... why didnt it weaken it the
first time.... its going to the same temp
Re: Can't shorten aluminum driveshaft? [Re: MR_P_BODY] #273955
04/01/09 03:13 PM
04/01/09 03:13 PM
Out West
Out West
I cannot see the logic in this either. I just wanted to get others opinions here. If it was a sales pitch, then it doesn't work when everyone elses comparable shafts are $200 less than yours across the board.
Re: Can't shorten aluminum driveshaft? [Re: MR_P_BODY] #273956
04/01/09 03:26 PM
04/01/09 03:26 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
maybe someone with more knowledge on the subjuect will help with this topic just sharing the info that was give to me
Re: Can't shorten aluminum driveshaft? [Re: 408strokerdart] #273957
04/01/09 03:29 PM
04/01/09 03:29 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
well no need to be like that now just trying to share info??? you don't even know what my drive shaft is so how can it be comparable
Good luck with your situation
Re: Can't shorten aluminum driveshaft? [Re: DRDart] #273958
04/01/09 03:33 PM
04/01/09 03:33 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Is it welded or bonded???
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Can't shorten aluminum driveshaft? [Re: CJK440] #273959
04/01/09 03:35 PM
04/01/09 03:35 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
mine is welded
Re: Can't shorten aluminum driveshaft? [Re: CJK440] #273960
04/01/09 04:43 PM
04/01/09 04:43 PM
Out West
Out West
Welded.
Re: Can't shorten aluminum driveshaft? [Re: 408strokerdart] #273961
04/01/09 04:44 PM
04/01/09 04:44 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
I am getting an aluminum driveshaft shortened two inches tommorow. No concerns were raised by the driveline shop.
76 Duster work in progress
Re: Can't shorten aluminum driveshaft? [Re: DRDart] #273962
04/01/09 04:51 PM
04/01/09 04:51 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
I think he was refering to the driveline shop's product with the "yours". Their's is $200 more than everyone elses, not your's.
At least, that's how I read it.
Re: Can't shorten aluminum driveshaft? [Re: G_bob] #273963
04/01/09 05:06 PM
04/01/09 05:06 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Apparently, the bonded ones cant be shortened, an experienced chassis guy over here tried welding one and it wouldn't take, he said that Mark Williams were not very forthcoming with the type of alloy they are made from.
I have got a welded one which i'm having shortened, so i'm interested in the outcome here.
Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Can't shorten aluminum driveshaft? [Re: deaks] #273964
04/01/09 06:24 PM
04/01/09 06:24 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Denny's built mine and shortened it after I put a dana in. There were no issues as they cut the end off and tossed it. They welded a new one on.It cost nearly as much as a whole new shaft to have it shortened.
Re: Can't shorten aluminum driveshaft? [Re: 408strokerdart] #273965
04/01/09 07:05 PM
04/01/09 07:05 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Now I'm confused.
I can understand why the staff was told to say "it can't be done", because of legal issues, etc.
If the ends are deeply inserted and mechanically locked (spline/flute) in the tube before welding I'd think it would be a nightmare to try to un-do or re-do this.
But.. why would a weld cutting only the tube itself not be possible?
Can't be strength - if you move down the tube 6" so the area hasn't been heated at all, a simple sleeve or stub insert makes the new joint far stronger than the original tube with only a few ounces lost.
Boffin Emeritus
Re: Can't shorten aluminum driveshaft? [Re: deaks] #273966
04/01/09 11:49 PM
04/01/09 11:49 PM
Out West
Out West
Mike
It is their welded version and the tube is clearly marked 6061 T6 aluminum. I am sure that the tube has a short register in it to maintain concentricity and then is welded. I don't believe that it can't be shortened. It might be cost prohibitive to do, but not possible?
Anyone need a shaft for a 727/Dana 60 111" A-body?
Guess I will post up in the classifides and get a new one on order.
Re: Can't shorten aluminum driveshaft? [Re: 408strokerdart] #273967
04/02/09 12:10 AM
04/02/09 12:10 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Dont give up yet! The only problem I see with shortening a shaft is the amount of change in the length. Under a 1/2" may not be possible because of the previous welds width that needs to be cut out to get to fresh tube. mike
Re: Can't shorten aluminum driveshaft? [Re: Sport440] #273968
04/02/09 12:36 AM
04/02/09 12:36 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
If the need to shorten it is caused by just the thickness of the mid-plate, that is probably the case.
