904 trans with a 2.74 first gear ? #2738936
02/02/20 10:21 AM
02/02/20 10:21 AM
Florida STAYcation
dOrk ! Offline OP
The village idiot's idiot
dOrk !  Offline OP
Florida STAYcation
....or is this known as a 999 trans ? What years and model cars did this come in ?
Re: 904 trans with a 2.74 first gear ? [Re: dOrk !] #2738964
02/02/20 11:27 AM
02/02/20 11:27 AM
A727Tflite Offline
A727Tflite  Offline
The trans gear ratios and trans designations are independent of each other.
The use of the low gearset came about to allow use of a numerically lower rear axle ratio for fuel economy - used in either a 904/998/999.
The 904/998/999 designation came from relative torque capacity - the number of clutch discs and band widths used.
My recollection is the low gearset became available in 1980.
Re: 904 trans with a 2.74 first gear ? [Re: A727Tflite] #2739069
02/02/20 03:44 PM
02/02/20 03:44 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Just about any Mopar that had 2.45:1 and 2.20:1 ring and pinion had the A999.
My J body Mirada did.
The 1995 GTE Phone repair Dodge B van with the 3.9 we scrapped did also.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: 904 trans with a 2.74 first gear ? [Re: Dave_J] #2739097
02/02/20 05:04 PM
02/02/20 05:04 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
The 80s fury's ,diplomat's and fifth avenues were good sources, some of the wheel drive trucks in those years had them too
Re: 904 trans with a 2.74 first gear ? [Re: dOrk !] #2739098
02/02/20 05:07 PM
02/02/20 05:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
First A999 was '74, first low gear set was '80, by '82 all of the 904 family had the low gear set.
Re: 904 trans with a 2.74 first gear ? [Re: John_Kunkel] #2739202
02/02/20 10:45 PM
02/02/20 10:45 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
a999 also had a 5 clutch front drum
Re: 904 trans with a 2.74 first gear ? [Re: John_Kunkel] #2739203
02/02/20 10:45 PM
02/02/20 10:45 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
How do you read the stamping on the transmission cases to determine the year of manufacture?
Re: 904 trans with a 2.74 first gear ? [Re: Jjs72D] #2739207
02/02/20 11:03 PM
02/02/20 11:03 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
As I understand it, all 8 cylinder. lock up trans (late 70s, 80s F bodies, big cars) have the 2.74. Correct?
Re: 904 trans with a 2.74 first gear ? [Re: Jjs72D] #2739372
02/03/20 04:06 PM
02/03/20 04:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The last 4 digits of the numbers stamped on the pan rail are the build date based on a 10,000 day calendar. Post the number to decode.
None of the 904 family had the low gear set in the seventies.
Re: 904 trans with a 2.74 first gear ? [Re: CMcAllister] #2739853
02/05/20 08:00 AM
02/05/20 08:00 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I have two 8 cylinder. lock up trans that don't have low gear sets or 5 disc drums.. There are a lot of variations so you don't really know what you have until you tear it down.
Re: 904 trans with a 2.74 first gear ? [Re: RTSE4ME] #2740248
02/06/20 10:08 AM
02/06/20 10:08 AM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
What specific vehicles are those ?
Re: 904 trans with a 2.74 first gear ? [Re: RTSE4ME] #2740315
02/06/20 01:06 PM
02/06/20 01:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's true of any aged trans, never know what's been done at overhaul but the part number stamped in the pan rail tells how it left the factory. What inside parts are correct can be determined by perusing the factory parts catalog.
Re: 904 trans with a 2.74 first gear ? [Re: dOrk !] #2740901
02/08/20 09:56 AM
02/08/20 09:56 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
They were early 80s cars if I remember correctly. I looked up the numbers. I scrapped one of the cases because it was cracked and the other is in my race car. I tried to get the numbers off it but the shifter bracket is in the way.
John is correct one of the tranny's was gone through but the one I ended using looked untouched but who knows.
When I bought all my parts from CRT he told me about all the variations he has seen.
Re: 904 trans with a 2.74 first gear ? [Re: John_Kunkel] #2743306
02/15/20 08:05 PM
02/15/20 08:05 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I've worn Google out....and I must be wording my search wrong. Can't find what my transmission came out of! It's a lockup for sure. The number on the drivers side of the pan rail is P4295887 7966 5768. I'm hoping it has the low 1st gear. I'm putting it in a 65 Barracuda. Any help appreciated. bow
Re: 904 trans with a 2.74 first gear ? [Re: JDMopar] #2743633
02/16/20 04:06 PM
02/16/20 04:06 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Looks like 84-85 904 in a big car (Mirada, Cordoba, 5th Ave). 318.
Best way to tell is pull it apart and look.
Re: 904 trans with a 2.74 first gear ? [Re: CMcAllister] #2743655
02/16/20 04:57 PM
02/16/20 04:57 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I think that the lockup usually goes hand in hand with the low gear, they did it because they were using some steep gears like 2.2:1. I'm pretty sure my fifth avenue has the low 1st and the convertor locks up around 54 mph
Re: 904 trans with a 2.74 first gear ? [Re: CMcAllister] #2743668
02/16/20 05:37 PM
02/16/20 05:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 904 trans with a 2.74 first gear ? [Re: John_Kunkel] #2743684
02/16/20 06:27 PM
02/16/20 06:27 PM
JDMopar Offline
JDMopar  Offline
bow Thank you guys. Now I know what year parts to buy if I get brave enough to tackle it myself. My local transmission shop has been good to me by helping me with late model stuff, and has yet to charge me a dime to answer questions. He quoted me a very fair price for a bench job, so I will probably just throw it his way. Thanks again! up
Re: 904 trans with a 2.74 first gear ? [Re: JDMopar] #2743685
02/16/20 06:32 PM
02/16/20 06:32 PM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
JD ... define reasonable?
Re: 904 trans with a 2.74 first gear ? [Re: dOrk !] #2743763
02/16/20 09:45 PM
02/16/20 09:45 PM
JDMopar Offline
JDMopar  Offline
$600 with shift kit and converter.
