Re: E body door panel crack
[Re: 71ragtop]
#2739534
02/04/20 08:09 AM
02/04/20 08:09 AM
Posts: 1,106 michigan
440whiteboy
michigan
Has anyone had success in repairing a crack in an E body door panel, if so any tips or advice, thanks I used epoxy 2 part mix kit Eastwood Company has many products - type in the search box - plastic repair...
They only see Stars... when hit by a Mopar!
[Re: 440whiteboy]
#2739536
02/04/20 08:18 AM
02/04/20 08:18 AM
Posts: 4,922 new berlin wisconsin
Mr T2U
Has anyone had success in repairing a crack in an E body door panel, if so any tips or advice, thanks I used epoxy 2 part mix kit Eastwood Company has many products - type in the search box - plastic repair... i am a autobody tech and repair plastic regularly. the panels are made out of polypropylene type plastic. repair of this plastic require use of adhesion promoter with a special epoxy. make sure you use the correct products for the repair. if you use the wrong products it will only be a temporary repair.
perception is 90% of reality
[Re: Mr T2U]
#2740317
02/06/20 01:09 PM
02/06/20 01:09 PM
Posts: 821 On the open road
Hrtbkr
On the open road
Hello Mr T@U. There's a bewildering number of products out there. Can you tell us what brand and part number you use? Thanks
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: Hrtbkr]
#2740475
02/06/20 08:00 PM
02/06/20 08:00 PM
Mr T2U
first a proper HOME repair might not be possible economically due to equipment costs and materials. we use 3M plastic repair system at our shop.they are dual cartridge tubes with special mixing tips. they also require the use a special applicator gun to use also. i think the cartridges are in the $75 range and 2 tips are included. don't know what the gun costs, we got ours for free when we bought a starter repair pack. the first test is cut a SMALL strip of plastic, put in in a small amount of water. push it to the bottom. if it floats you will need adhesion promoter before the epoxy. adhesion promoter is also around $40. sou might need a reinforcement mesh to support the repair also, depending on where the crack is.. i don't know what that costs. after it's glued you will need plastic body filler material, plastic primer, them paint.
this is the cost to chemical repair. now if you find a body shop with a plastic welder the crack could probably be repaired in 15 min and the rod is $5. them plastic body filler and primer. then paint.
our shop rarely uses glue to repair plastic anymore, depending on the plastic being repaired. most of it is welded. better repair, faster repair, stronger repair and cheaper repair.
SEE MY FIRST POST.
[Re: mrob]
#2740739
02/07/20 05:52 PM
02/07/20 05:52 PM
Mr T2U
when i screw up and break a interior trim panel that has texture. i clamp the broken area to keep the crack as small as possible then just weld the back side of the panel. if you do it properly the crack is barely noticeable. i don't repair interior parts often. but when the interior trim guys do a repair they have textured panels and mold the texture back into the repaired area.
