E body door panel crack #2739181
02/02/20 09:36 PM
02/02/20 09:36 PM
71ragtop Offline OP
71ragtop  Offline OP
Has anyone had success in repairing a crack in an E body door panel, if so any tips or advice, thanks
Re: E body door panel crack [Re: 71ragtop] #2739245
02/03/20 08:13 AM
02/03/20 08:13 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
they can be plastic welded and repaired just like car bumpers
perception is 90% of reality
Re: E body door panel crack [Re: 71ragtop] #2739456
02/03/20 10:06 PM
02/03/20 10:06 PM
Ohio
P
PDR Dude Offline
PDR Dude  Offline
P
Ohio
One of those interior repair guys should be able to handle it. Most of those guys do excellent work. They can re-dye and re-grain the surface also. Should be less than $100.
Re: E body door panel crack [Re: PDR Dude] #2739473
02/03/20 10:54 PM
02/03/20 10:54 PM
71ragtop Offline OP
71ragtop  Offline OP
Thanks can you recommend a good interior company?
Re: E body door panel crack [Re: 71ragtop] #2739491
02/03/20 11:50 PM
02/03/20 11:50 PM
Ohio
P
PDR Dude Offline
PDR Dude  Offline
P
Ohio
Call or stop by one of your local car dealers. See who they use. Typically they'll share contact information...
Re: E body door panel crack [Re: 71ragtop] #2739534
02/04/20 08:09 AM
02/04/20 08:09 AM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
I used epoxy 2 part mix kit
Eastwood Company has many products -
type in the search box - plastic repair...
They only see Stars...
when hit by a Mopar!
Re: E body door panel crack [Re: 440whiteboy] #2739536
02/04/20 08:18 AM
02/04/20 08:18 AM
Mr T2U Offline
Mr T2U  Offline
i am a autobody tech and repair plastic regularly. the panels are made out of polypropylene type plastic. repair of this plastic require use of adhesion promoter with a special epoxy. make sure you use the correct products for the repair.
if you use the wrong products it will only be a temporary repair.
Re: E body door panel crack [Re: Mr T2U] #2740317
02/06/20 01:09 PM
02/06/20 01:09 PM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
Hello Mr T@U. There's a bewildering number of products out there. Can you tell us what brand and part number you use? Thanks
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: E body door panel crack [Re: Hrtbkr] #2740475
02/06/20 08:00 PM
02/06/20 08:00 PM
Mr T2U Offline
Mr T2U  Offline
first a proper HOME repair might not be possible economically due to equipment costs and materials.
we use 3M plastic repair system at our shop.they are dual cartridge tubes with special mixing tips. they also require the use a special applicator gun to use also.
i think the cartridges are in the $75 range and 2 tips are included.
don't know what the gun costs, we got ours for free when we bought a starter repair pack.
the first test is cut a SMALL strip of plastic, put in in a small amount of water. push it to the bottom. if it floats you will need adhesion promoter before the epoxy.
adhesion promoter is also around $40.
sou might need a reinforcement mesh to support the repair also, depending on where the crack is.. i don't know what that costs.
after it's glued you will need plastic body filler material, plastic primer, them paint.
this is the cost to chemical repair. now if you find a body shop with a plastic welder the crack could probably be repaired in 15 min and the rod is $5.
them plastic body filler and primer. then paint.
our shop rarely uses glue to repair plastic anymore, depending on the plastic being repaired. most of it is welded. better repair, faster repair, stronger repair and cheaper repair.
SEE MY FIRST POST.
Re: E body door panel crack [Re: Mr T2U] #2740608
02/07/20 10:01 AM
02/07/20 10:01 AM
Maryland
mrob Offline
mrob  Offline
Maryland
Hi MrT2U,
Not trying to hijack this post, but if the crack is in an area with texture (pebble grain) how do you restore the texture in the repaired area?
Re: E body door panel crack [Re: mrob] #2740739
02/07/20 05:52 PM
02/07/20 05:52 PM
Mr T2U Offline
Mr T2U  Offline
when i screw up and break a interior trim panel that has texture. i clamp the broken area to keep the crack as small as possible then just weld the back side of the panel. if you do it properly the crack is barely noticeable.
i don't repair interior parts often. but when the interior trim guys do a repair they have textured panels and mold the texture back into the repaired area.
Re: E body door panel crack [Re: Mr T2U] #2740760
02/07/20 07:36 PM
02/07/20 07:36 PM
Eagle, Idaho
Neil Offline
Neil  Offline
Eagle, Idaho
Would the end of the crack need to be stop drilled before repairing?
I always do that on grilles to keep it from restarting again. Never done a door panel though...…...
Re: E body door panel crack [Re: Neil] #2740762
02/07/20 07:40 PM
02/07/20 07:40 PM
Mr T2U Offline
Mr T2U  Offline
wouldn't hurt
