A Bad Day For The Ron Capps Team
#2738922
02/02/20 09:32 AM
02/02/20 09:32 AM
Posts: 1,796 Greer, SC
TooMany62s
Greer, SC
Re: A Bad Day For The Ron Capps Team
[Re: TooMany62s]
#2739318
02/03/20 12:44 PM
02/03/20 12:44 PM
Posts: 22,719 Bitopia
jcc
Bitopia
So they are normally Tire/brake/bearing failure related fires IMO. Wonder if there are currently heat sensitive driver warning devices available to help reduce these outcomes with expensive cargo? Doesn't seem much of. a stretch with current technology. Could have been worse.
[Re: jcc]
#2739377
02/03/20 04:57 PM
02/03/20 04:57 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
railroads use something similar to alert crews of hot wheel bearings
1981 Dodge D150 360 auto
[Re: basketcase]
#2739567
02/04/20 10:10 AM
02/04/20 10:10 AM
jcc
Bitopia
Yes something like that, but I believe the RR solution is fixed, and monitors rail cars as they pass by.
Seems like it might also reduce road side mysterious brush fires.
Last week I stopped and put out a fire shoulder fire that apparently was started by trailer wheel fire I passed later parked on the shoulder farther down the road.
