Re: Leaf spring inboard kit Mopar
[Re: justinp61]
#2739557
02/04/20 09:44 AM
02/04/20 09:44 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
For the front spring eye bolts? Mine are 5/8". Did u use a 5/8 drill bit?
[Re: RAY1969CARS]
#2739585
02/04/20 10:49 AM
02/04/20 10:49 AM
Posts: 8,905 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I was moving it back a 1/4inch to help with tire clearance I’m also mini tubing the car. Putting a 10inch rim on the car What model car ?? A 10" wheel/tire combo will fit a b-body without spring relo or mini tubs. That's a LOT of work and expense for zero gain - ask me how I know !!!
[Re: RAY1969CARS]
#2739662
02/04/20 02:28 PM
02/04/20 02:28 PM
Posts: 11,685 W. Kentucky
justinp61
W. Kentucky
I was moving it back a 1/4inch to help with tire clearance I’m also mini tubing the car. Putting a 10inch rim on the car I moved mine back 1" on the Dart, it went a bunch of 1.38 60' with a pump 93 408.
[Re: justinp61]
#2739812
02/04/20 11:22 PM
02/04/20 11:22 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
When I ran a 275 I moved the rearend back 1/2" to get clearance. 275 60 ???
[Re: RAY1969CARS]
#2740980
02/08/20 03:41 PM
02/08/20 03:41 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
[Re: RAY1969CARS]
#2741113
02/09/20 12:23 AM
02/09/20 12:23 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
The frame rails on my son's 1968 Dart 270 are different. From the wheelwell lip to the frame rails outter wall the right side is about 7/16 shorter. The tire will rub on the right but not on the left. I thought I had messed up so I got under with a plumb bob and sharpie and made all sorts of marks on my concrete floor. My spring boxes are welded in the right place on the frame rails but not in the centerline of the whole body. It is still 7/16 inch offset. FUBAR! I ASSuME'd the factory was close....
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: moparx]
#2741262
02/09/20 04:00 PM
02/09/20 04:00 PM
Dave_J
Auburn WA
the quality of the factory underbody was horrible "back in the day", and comparing your frame/chassis/unibody measurements to the measurements found in the FSM is sure to find your measurements are "slightly" [ ] off ! as said, check for level and square, and for kicks, run some strings to the grease fittings in your lower ball joints to check the alignment of your front/rear suspension to each other. THIS ^^^ BEFORE welding the boxes in!!! When the 68 Dart 270 had the 7 1/4 with 155/78 13's it did not look like the axle was 7/16 inch offset to the right. But with the 325/45 20's you can tell real quick. If I had known it would have been a bit of work but I would have offset the boxes 7/32's to the left side. It is done and the easy fix is to offset the spring perch's and reweld them on the 8 3/4 housing.
