Put the hole where it needs to be. I realize that answer might not seem to be helpful but it is the correct answer. It all depends on ride height and tire size and where you want the wheel in the fender and all of that. Mock it up, measure it 5 or 6 times then drill it. It isn't easy making sure that each side is perfectly straight and square to the chassis.
