Any Issues Welding M/T Cast Valve Covers #2737026
01/27/20 11:43 AM
01/27/20 11:43 AM
Morrow, OH
markz528 Online content OP
markz528  Online Content OP
Morrow, OH
Anyone ever weld M/T Valve Covers? Any issues? Any suggestions?
Re: Any Issues Welding M/T Cast Valve Covers [Re: markz528] #2737035
01/27/20 12:08 PM
01/27/20 12:08 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I had my friend tig weld my cast Mopar Performance valve cover. One of the corners cracked around the bolt hole. Just got to get it good and clean. Welded about 5 years ago. I put the valve cover on, so that you can't see it. Passenger side , in the back, lower hole.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Any Issues Welding M/T Cast Valve Covers [Re: markz528] #2737036
01/27/20 12:11 PM
01/27/20 12:11 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Brian Slowe welded breather tubes onto a set for me. Said he didn't have any issues.
Re: Any Issues Welding M/T Cast Valve Covers [Re: markz528] #2737122
01/27/20 03:46 PM
01/27/20 03:46 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
In a roadside emergency, I glued a rear corner with bolt hole back on with the fast dry JB Weld. It held for thousands of miles and several months until the cover was replaced because of it. I believe it would still be fine to this day.
Re: Any Issues Welding M/T Cast Valve Covers [Re: Dartsport540] #2737249
01/27/20 09:10 PM
01/27/20 09:10 PM
iagree
Me too up
Re: Any Issues Welding M/T Cast Valve Covers [Re: Cab_Burge] #2737273
01/27/20 10:10 PM
01/27/20 10:10 PM
Morrow, OH
Morrow, OH
Thanks! Any suggestions on what rod material to use?
I'm on a project that is ballooning in complexity. I believe that I will need to add material and then remachine. Will post pics when I'm done.
Need to practice. My tig welding skills are rusty................
Re: Any Issues Welding M/T Cast Valve Covers [Re: markz528] #2737283
01/27/20 10:44 PM
01/27/20 10:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A general purpose aluminum rod will do just fine. I don't know what you're doing BUT get that sucker spotlessly clean first.. I'd run it through your parts washer then a couple cycles in your dishwasher. Then clean both the area and the rod with acetone just before welding.
Re: Any Issues Welding M/T Cast Valve Covers [Re: Stanton] #2737286
01/27/20 10:53 PM
01/27/20 10:53 PM
Morrow, OH
Morrow, OH
I need to move some bolt holes. Will de-grease it and I have a good industrial ultrasonic cleaner. Will put it through several cycles. Just finished welding my oil pan and it got the pan nice and clean for welding.
I always clean with acetone as a final clean. I can tig weld just haven't done it in a couple years.
Re: Any Issues Welding M/T Cast Valve Covers [Re: markz528] #2737325
01/28/20 02:51 AM
01/28/20 02:51 AM
I had my M/T covers welded from the inside up
Re: Any Issues Welding M/T Cast Valve Covers [Re: Cab_Burge] #2737491
01/28/20 06:31 PM
01/28/20 06:31 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Abe Lincoln
