Any Issues Welding M/T Cast Valve Covers
#2737026
01/27/20 11:43 AM
01/27/20 11:43 AM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Anyone ever weld M/T Valve Covers? Any issues? Any suggestions?
Re: Any Issues Welding M/T Cast Valve Covers
[Re: markz528]
#2737035
01/27/20 12:08 PM
01/27/20 12:08 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I had my friend tig weld my cast Mopar Performance valve cover. One of the corners cracked around the bolt hole. Just got to get it good and clean. Welded about 5 years ago. I put the valve cover on, so that you can't see it. Passenger side , in the back, lower hole.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: markz528]
#2737122
01/27/20 03:46 PM
01/27/20 03:46 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
In a roadside emergency, I glued a rear corner with bolt hole back on with the fast dry JB Weld. It held for thousands of miles and several months until the cover was replaced because of it. I believe it would still be fine to this day.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Cab_Burge]
#2737273
01/27/20 10:10 PM
01/27/20 10:10 PM
markz528
Morrow, OH
Thanks! Any suggestions on what rod material to use?
I'm on a project that is ballooning in complexity. I believe that I will need to add material and then remachine. Will post pics when I'm done.
Need to practice. My tig welding skills are rusty................
[Re: Stanton]
#2737286
01/27/20 10:53 PM
01/27/20 10:53 PM
markz528
Morrow, OH
A general purpose aluminum rod will do just fine. I don't know what you're doing BUT get that sucker spotlessly clean first.. I'd run it through your parts washer then a couple cycles in your dishwasher. Then clean both the area and the rod with acetone just before welding. I need to move some bolt holes. Will de-grease it and I have a good industrial ultrasonic cleaner. Will put it through several cycles. Just finished welding my oil pan and it got the pan nice and clean for welding. I always clean with acetone as a final clean. I can tig weld just haven't done it in a couple years.
