BG 625 road demon info ?
#2735626
01/22/20 03:28 PM
01/22/20 03:28 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I have what I think is a 625 road demon but I can't find any proper details on it. Number on the metering block is A12400X, It came in the box with 850 vs on it but I think it's smaller, it's got 58 primary jets, 74 main jets and a 6.5 PV, 1.56, 1.69 butterflies. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: BG 625 road demon info ?
[Re: deaks]
#2735673
01/22/20 08:00 PM
01/22/20 08:00 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The 525 and 625 are the same “size”(1.280 venturi). The 525 has annular boosters, 625 downleg.
58/74 jetting is stock for the 525. 70/78 jetting is stock for the 625
[Re: fast68plymouth]
#2736245
01/24/20 06:20 PM
01/24/20 06:20 PM
deaks
robin hood country
It's got downleg boosters and 58, 74 jetting ?
[Re: deaks]
#2736259
01/24/20 06:43 PM
01/24/20 06:43 PM
fast68plymouth
So. Burlington, Vt.
Well, according to my old Demon catalog...... downleg boosters would be a 625, which “should” have come with 70/78 jets.
The description states that the “Road Demon 625” has downleg primary boosters and annular secondary boosters.
The 525 has annular front and rear.
[Re: deaks]
#2736878
01/26/20 07:51 PM
01/26/20 07:51 PM
fast68plymouth
So. Burlington, Vt.
Can’t see the primary boosters with the choke closed.
[Re: deaks]
#2737123
01/27/20 03:46 PM
01/27/20 03:46 PM
fast68plymouth
So. Burlington, Vt.
Looks like annular boosters front and rear to me...... which would make it a 525.
The 625 has smaller/thinner primary boosters.
#2737128
01/27/20 03:55 PM
01/27/20 03:55 PM
deaks
robin hood country
I thought annular boosters had small holes in ? Do you think the 525 will be too small for my fairly mild magnum 360 ?
[Re: deaks]
#2737129
01/27/20 03:57 PM
01/27/20 03:57 PM
fast68plymouth
So. Burlington, Vt.
Just try it. You’ll either like it or you won’t.
The only difference in flow between that and a 625 is the primary boosters.
It looks like it’s a 525 to me, and it sounds like it has the stock jets in it.
