I bought one of those from them on eBay just a few weeks ago and installed. I can attest,it is a fantastic product and easy install. I'll give you a couple of tips the seller gave me when installing and some I used when doing mine: 1) don't be tempted to install the needle in car (it's easy to remove). 2) Use a 2 part epoxy that sets in 1-2 minutes when gluing the new needle on. 3) lube up the speedo cable when you do the job if it was wobbling when this happened as that's mostly likely the cause. I used a spoonful of SuperLube mixed with dry graphite until the lube was shiny black and lubed it till about 9 inches from the top of the cable. Just put the lube between your fingers as you slide it back into the case.
